B16 or b18 tranny
Old Oct 2, 2013 | 11:20 AM
kou-integra98's Avatar
Default B16 or b18 tranny
Since my tranny is making noises I'm planning to open it up and check it and I got a b16a SI motor from my friend and planning to try on the b16 tranny do you guys think it'll be good? I dd/cruise with my car and track here and there. I just have basic Bolts on
Old Oct 2, 2013 | 02:11 PM
B_Swapped93's Avatar
Default Re: B16 or b18 tranny
It won't be your friend on the highway...it may make the car "feel faster" what engine/trans is currently in the car ?
Old Oct 2, 2013 | 02:16 PM
Fliptard's Avatar
a b16 trans is short geared, so you will have faster acceleration. and will stay higher in the RPM's on the highway, but not bad. I have a 98+ JDM ITR trans with a 4.7 FD and at 62mph i'm at roughly 4300 RPMs.
An Ls (b18b1) trans will be low geared, more for economy. Having long gears will make each gear "go faster" but also taking longer to get to the end of each gear.
Old Oct 2, 2013 | 02:21 PM
thewrai6th's Avatar
I'd match the transmission to the engine RPM max. I regret the Type-R gearingwith GSR engine when I am cruising on the freeway and vtec is kicking on and off at 80 mph. It used to stay off until 90 or a downshift. A Type R engine revs higher and the ECU puts the vtec xover higher, so the gearing/vtec xover is not a problem with a matching setup.
I guess it also depends if you are going for all out performance, or comfort/gas mileage. The shorter gears don't just make it feel faster, it increases acceleration by giving up top end MPH.
Old Oct 2, 2013 | 03:47 PM
3rdtimecharmer's Avatar
10 Year Member
i have a b16 tranny. i cruise at 60-65 and stay within 3000-35000 RPM. the slow driving doesnt bother me. i like it. the power is there when i need it. but going 80 mph is a no go. kills my gas anyways.
F2B set up in my integra.
also i commute about 52 miles to and from work every day (about 26 miles to work and 26 miles from work). i avg 28-30 mpg. 32 on a good week :]
Old Oct 2, 2013 | 04:47 PM
dc2LS's Avatar
The b16 tranny as previously stated has a short gear ratio which it will help with your acceleration and the b18b tranny will definetly be good if your looking for fuel economy.
Old Oct 2, 2013 | 06:09 PM
I have a b18c1
Old Oct 3, 2013 | 12:31 AM
mouab18c1's Avatar
Just keep the gsr tranny or get one if your current transmission is taking a dump.
JWhip1
33
Aug 28, 2009 01:57 PM
B16-CRX
Jan 12, 2007 11:55 AM
hspoon
Dec 8, 2006 12:45 PM
rickturboteg
Aug 7, 2006 06:20 PM
osideracer1
Aug 19, 2005 09:00 AM
