Transmission & Drivetrain Gearboxes, Differentials, Clutches
Manual problem and i cant find a solution
Old Oct 1, 2013 | 08:18 PM
Fogol's Avatar
Default Manual problem and i cant find a solution
I just got into a honda. Finally. And i can find out why its doing whatever it is. What happens is. When my car is on. I can move through gears with no clutch. But it wont go anywhere. When i apply the clutch and try with the car on, it wont shift at all. My friend and i got underneath it today and there is a metal rod comig from the bottom of the stick goin into the tranny. My friend says thats what he thinks is wrong with it. But im not sure. Any help from you pros would be a delight.
Old Oct 2, 2013 | 02:04 AM
94acuralsv's Avatar
Default Re: Manual problem and i cant find a solution
Is that "rod" moving while your going thru the motions of gear change?
Old Oct 2, 2013 | 02:38 AM
Fliptard's Avatar
pics of said "rod"?
It's most likely the shift linkage.
Old Oct 2, 2013 | 10:48 AM
Fogol's Avatar
Yeah ill post pictures. But idk howw/.-
Old Oct 2, 2013 | 01:59 PM
94EG8's Avatar
Seagull Management
I'm assuming you meant it shifts ok with the car off, but not running.
Generally either the clutch master or slave cylinder has failed. Somewhat less commonly the clutch disc itself will spit a damper spring and it will get jammed between the disc and the flywheel preventing the clutch from releasing. Less common still is a destroyed throwout bearing.
Old Oct 2, 2013 | 06:29 PM
Fogol's Avatar
Well it shifts while itss on aswell. The only time it doesnt shift is when the car is on and the clutch is fully pressed. And its cable not hudraulic
MugenGTR
Jan 29, 2012 02:14 PM
mhohisel
Apr 25, 2010 11:02 AM
civickiller
Nov 8, 2005 03:17 AM
Baltz
19
Aug 24, 2004 06:59 PM
mike1114
Dec 9, 2003 12:35 PM
