speed sensor not working????
Old Oct 1, 2013 | 05:15 PM
nenetech's Avatar
Default speed sensor not working????
wats up honda tech .. i have recently swapped my original em1 w a semi build gsr for boost. swap went well w barely no hiccups. but now my speedo does not work read a few schematics provided here and said blue w white wire is the vss signal went to the transmission and found that white w blue disconected i opened the harness both ways and find no rip wires at all.. than googled it again and said signal wire is yellow and black now im confuse and just wanna know where does that blue with white wire goes to see if speedo will work again.. also using chipped p72 ecu w rywire jumer harness obd11b to obd1 .. any helpis appreciated.
Old Oct 1, 2013 | 05:40 PM
KidRuthless's Avatar
Default Re: speed sensor not working????
Trying checking your fuses first may have a blown fuse
Old Oct 1, 2013 | 08:32 PM
nenetech's Avatar
all fuses are checked and good specifically alt fuse which is vss also. anyone else.. anyone share a schematic showing how to wire this blue w white wire ????
Old Oct 2, 2013 | 12:01 PM
http://www.ff-squad.com/technet/wiring.obd2a.htm
Here's the wiring for integra and civic's
chrysler kid
62
Jan 23, 2019 04:23 AM
CivicInspired
Honda Civic (2001 - 2005)
Aug 17, 2007 08:44 PM
nocturnal EG
Audio / Security / Video
16
Nov 3, 2006 08:04 AM
Chuji
Jan 23, 2003 01:19 PM
