vtec solenoid question
Old Oct 26, 2002 | 01:56 PM
ball's Avatar
Default vtec solenoid question
is there a way to test and see if the vtec solenoid is good?????
Old Oct 26, 2002 | 02:24 PM
altoid's Avatar
Default Re: vtec solenoid question (ball)
slap that wonder on the head, and rev it up to engage vtec, if it doesn't engage its probably done gone and broke it's self
Old Oct 26, 2002 | 05:25 PM
mobrep's Avatar
New User
CEL + code 21 = Vtec Solenoid Valve - defective circuit or unplugged / defective solenoid valve
Old Oct 28, 2002 | 03:00 PM
PnX-R's Avatar
Yeah there's a way.. According to the wiring diagram to for a GSR.. All the solenoid does is ground the GRN/YEL wire for a 94 to 97 and ground the GRN/WHT for a 98 to 01 GSR.. So what I would do is indirectly test the solenoid by grounding the wire going into the solenoid.. And if it VTEC engages when you rev up to it, you've got a faulty solenoid or corrodded ground. Next you'll have to check the ground that the solenoid uses and make sure that it isn't dirty.. Hope that helps..
Old Oct 28, 2002 | 07:02 PM
Shea-bird's Avatar
New User
Default Re: vtec solenoid question (PnX-R)
hook up 12 volts to the solenoid and see if it clicks. I remember hearing that somewhere...can someone confirm this?
Old Oct 28, 2002 | 07:29 PM
MrTodd's Avatar
Default Re: vtec solenoid question (Shea-bird)
That's what I was thinking...
Old Oct 28, 2002 | 08:10 PM
USDM 4G VTEC's Avatar
yes if u put a cable from 12v+ to the green plug on the top of vtec sol.. green wire that comes off solenid, it should click... if it does its good..
Old Oct 29, 2002 | 03:54 AM
kranked91dx's Avatar
the clicking 12 volt thing is good, but you can also hook up a Multimeter on it to see if the coil is in good shape, since they don't got the same impedance , find a solenoid of the same model that work, check the impedance, then get back to yours and see if it's the same, don't wories if it change of less than 1 homs, your's is fuct up if it change more than 3 or 4 homs.
Old Oct 29, 2002 | 05:50 AM
Rob!'s Avatar
Default Re: vtec solenoid question (kranked91dx)
many many ways....
tarmax
Oct 20, 2010 11:40 AM
AnAccordIsForever
Jun 3, 2008 03:27 PM
JDM94HATCH
12
Nov 15, 2006 02:06 AM
94whitegsi
Sep 26, 2006 01:28 PM
