NEED SOME HELP
ok i need some help i am just have 2 things left for my build pistons and cams
b18c1 block
b18c1 rods
b18c1 crank
b16a head with
supertec valve springs
oem retaners
supertec flat valves on the ex only
all casting marks on the intake are smoothed down and port mached to a p30 intake and the intake is port matched to a 68mm tb the ecsoust side is port mached and completely smooth
i am trying to use close to oem pistons i need a .20 overbore piston
i want my compression to be in the 11s
i was going to use pr3 pistons but i would like jdm p30s or jdm itr pistons i am having a hard time finding them links would help
i want a nice dd sleeper setup was going to use blox type b cams or s2p1 cams i just want a car thats going to last 100000+ not 50000 not looking for more than a type r power out put in my db7
also i heard there where some problems with the pr3s on the gsr rods
thanks for the help guys
btw i am in and around Jacksonville and Wilmington nc if u know a good shop to put this together let me know
b18c1 block
b18c1 rods
b18c1 crank
b16a head with
oem retaners
http://www.hondapartsunlimited.com/p...nkshaft-piston
P30 pistons. Standard or oversized. $54 each.
Rings are another $32 per piston.
i am with u i would get Nippon before spending 400 for pistons i am trying to do mostly OEM parts
Honestly I would run it at 81.5 or 82mm with PR3 pistons. I had that setup in my old car. 82mm GSR block crank and rods w/ pr3's, B16 head w/ ITR cams and a B16 tranny and it ran consistent 13.9's on street tires with 2.1 60's in a ex coupe that weighed almost 2600 with me in it. My CR was right at 11.4:1
As for cams....Unless you have a lot of stored knowledge somewhere, or have someone do the build and install for you, I would not touch the pro 1's. They are an animal all of themselves. Stick to the Skunk2 tuner lineup or somethijng similar, they are easy to tune and use and always deliver. Plus you WILL HAVE TO build your head to run anything of that nature. Do some searching and reading.
Tell that someone to go pack sand, that's the most moronic thing I have ever heard. My ran my GSR w/ B16 slugs for 25k and it was still going strong until the day it was stolen. You can't go wrong with more displacement and more compression, within reason of course.
heads built valve springs new OEM intake valves port mached just looking for cams and i am going to have it put together by a machine shop that does Honda's and ill put it in and bring it to tune i have built a few Ford and chevy motors and a lot of honda bikes and one b18c1 just had itr pistons and cams i was just throwing out some ideas on a good mostly OEM build
To be 100% honest, putting in bigger cams and a bigger TB is nearly pointless with the P30 IM. Smallest Bvtec IM. All that air is just going to hit a bottle neck before it even gets to the cams to breathe. Look into a ITR or Skunk2 for your setup and that alone will free up HP not even cams will get you.
RITLINBOY-91.SI
12
Jun 9, 2012 09:46 PM
Angel4768
Oct 4, 2010 12:54 PM
WhiteLightening
Feb 19, 2006 03:19 PM
