what are symptoms of a seized motor?
Old Oct 26, 2002 | 01:28 PM
b18bvudoo's Avatar
New User
Default what are symptoms of a seized motor?
other than the fact that it wont start. the car cranks, but it wont turn on.....i think i i had a little less than 2 qts of oil in there....i was actually on my way to get some oil. car shut down at a traffic light ...had to tow it home. i think the motor might be seized.
anyways, went to get oil, and put in 2 qts. checked the dipstick and oil level is actually a lot higher now than the 4 qt mark.
Old Oct 26, 2002 | 01:49 PM
SoulSurfer's Avatar
Default Re: what are symptoms of a seized motor? (b18bvudoo)
My mom seized her motor. Wouldn't even crank.
Old Oct 26, 2002 | 02:51 PM
BigMoose's Avatar
Seized motors are usually accompanied by:
1 A loud and unexpected noise
2 A sour feeling in the pit of your stomach
3 The inability for the crank to turn significantly thereafter!
The last motor I seized dropped a valve, gernaded the respective piston, and turned the rod into a pretzel. Everything stayed within the cast iron jacket however, making cleanup a snap.
From your description, you may have gotten off easy with just some ignition or other failure on your way to buy oil.
Regards,
BigMoose
Old Oct 26, 2002 | 03:20 PM
civictypenos's Avatar
check your compression.if the motor turns over than its not seized,posably blew the head gasket??no compression = wont start.
Old Oct 26, 2002 | 03:43 PM
boostinb18's Avatar
Default Re: what are symptoms of a seized motor? (civictypenos)
do you have spark?? fuel??
Old Oct 26, 2002 | 05:35 PM
ion_four's Avatar
Default Re: what are symptoms of a seized motor? (boostinb18)
if you had two quarts in there, you are fine man. The LAST(as in never again) time I had my oil changed at the dealership they didn't tighten the drain plug, so it started to back out while driving and weeped a couple quarts while driving a few miles to another store. About 10k miles later, my engine is running like a champ...oh, except it won't make a damned spark now
https://honda-tech.com/zerothread?id=316759 (not to ***** your thread)
I'd check for spark and fuel. most likely your problem. once I had a distributor explode right after changing my oil, too. I thought I'd run it dry and I was screwed haha.
Old Oct 26, 2002 | 05:38 PM
b18bvudoo's Avatar
New User
compression:
#1: 160
#2: 170
#3: 175
#4: 180
obviously #1 is dying, but i dont think that will prevent the car from starting. dont think its my head gasket cuz i never saw any white smoke coming from that area; i wasnt even boosting, and i have some compression.
ah man, guess i better save up for a gsr swap
i dont think its a fuel problem, not sure about spark....how would i check if it was getting spark? tia.
Old Oct 26, 2002 | 05:44 PM
pull the plug wire,put a screwdriver on the end of it,set it next to something metal on the car and turn the key,you should see a spark,unless you have a timing light,then just attach the timing light.
Old Oct 26, 2002 | 08:47 PM
redteg1's Avatar
compression:
#1: 160
#2: 170
#3: 175
#4: 180
white smoke that comes out during the compression test means the headgasket is no good? cuz white smoke came out of mine when i did the compression test before. and i could never find out why the compression was so weak in one of the cylinders...
PoMoNa_909_eM2
Honda Civic (2001 - 2005)
15
Oct 13, 2010 07:13 PM
Luward
Oct 29, 2007 07:35 AM
PaChiLa Leader
Apr 25, 2007 09:15 AM
EF8_03
Mar 12, 2007 02:51 PM
dsav4shawn
Oct 7, 2006 03:46 PM
