Gears and such for a 96 accord
Hi all
I need to know where to buy gears and bearings for a 96 honda accord
I understand these transmissions were only made a couple of years, the one I have has several stripped gears and have had no luck finding one in a junk yard around here
As I said in your other thread:
Find another trans. That thing got hot.
Looks like it was run with very low, no fluid for a long time, finally got hot enough to start welding 4th and 5th gear to the mainshaft at which point it shredded the gear teeth. If you take a file to the rest of the gears they're probably soft as butter (the file should skate on the gears) Usually you'll get some warning before this happens, normally it will start popping out of 5th before this happens.
This really past the point of what would be considered a cost effective rebuild. But if you really want parts Synchrotech or Geerspeed should have what you're looking for.
