water leak in back of block by the water pump!!!
Old Oct 26, 2002 | 01:14 PM
RenoRacing's Avatar
Default water leak in back of block by the water pump!!!
okay, i've tried a new gasket and everything for the waterpump but it continues to leak pretty fast(about 12oz every 30minutes). i can see it dripping but not the source, i can feel with my finger and its right at the bottom back part of the water pump. Where does water come from when the pumps bad, the weep hole location??? i have an b18a in there to let you know.
Old Oct 26, 2002 | 01:20 PM
altoid's Avatar
Default Re: water leak in back of block by the water pump!!! (HavokRacing)
did you put the gasket on correctly?
Old Oct 26, 2002 | 01:23 PM
RenoRacing's Avatar
Default Re: water leak in back of block by the water pump!!! (altoid)
yeah, i even put it on once when the motor was totally out of the car
Old Oct 27, 2002 | 09:07 PM
SlowEF's Avatar
try pulling the pump back out and use a little honda bond,or make sure there is no crimp in the gasket or divit in block
Old Oct 28, 2002 | 04:52 AM
civicwagonman's Avatar
Default Re: water leak in back of block by the water pump!!! (SlowEF)
is the water pump bad? coming out of drip hole? or possibly the gasket for the tube that runs over to the thermostat.
cstap
Oct 10, 2013 06:34 AM
tony_yang
Honda Civic (2006 - 2015)
Jan 28, 2011 03:49 PM
Champs32
Feb 14, 2009 07:28 PM
platinum00
Feb 13, 2005 12:39 PM
RenoRacing
Oct 27, 2002 08:40 PM
