00 Integra GS w P0420
Old Sep 28, 2013 | 06:28 AM
M-benz's Avatar
Default 00 Integra GS w P0420
The CEL is pop up so I went to Autozone to scan it ..the P0420 is the code that they gave me . The guy told me its 02 sensor but I don't know is it the upstream ( primary ) or the downstream ( underneath the car ) or maybe because of my CAT ? Can someone help please ?
Old Sep 28, 2013 | 10:42 AM
deving916's Avatar
Default Re: 00 Integra GS w P0420
I had this code in a 00 civic ex one time.
Do you have the cat on there still?
Old Sep 28, 2013 | 11:18 AM
M-benz's Avatar
Everything is still intact so how did u solve urs ?
Old Sep 29, 2013 | 03:47 AM
HondaPartsHero's Avatar
Technical Hero
Check for exhaust leaks before or in the cat. Otherwise generally its a bad cat.
Old Sep 29, 2013 | 06:27 PM
M-benz's Avatar
Hmm ok so it's not O2 sensors at all ?
Old Sep 30, 2013 | 04:47 AM
TheRealTegger's Avatar
No. Oxygen sensor problems would prompt different error codes.
Check for exhaust leaks, as directed before. If none, then the cat has deteriorated below the threshold that the engine's computer is programmed to consider acceptable.
One thing that dramatically reduces cat life is to allow the car to run out of gas, or to drive around with a very-low gas tank level. Honda warns about this in later Owner's Manuals.
Last edited by TheRealTegger; Sep 30, 2013 at 05:00 AM. Reason: Added info about cat-life reduction.
Old Sep 30, 2013 | 04:49 AM
UGAVtech's Avatar
It's an inefficiency code, this might help...
Old Sep 30, 2013 | 05:01 AM
If that really worked, don't you think somebody other than Scotty Kilmer would have picked it up by now?
Old Sep 30, 2013 | 02:37 PM
thewrai6th's Avatar
Standard code for bad catalytic converter. Can be caused by o2 sensor, but unlikely. If the Pri or Sec O2 sensor is bad, it will normally set off the code for a bad sensor.
Just an FYI, if you burn a lot of oil, plan on replacing it again within a couple years. I got sick of dealing with P0420 and got an O2 extender, but that won't work if you're trying to pass smog.
Old Oct 1, 2013 | 04:48 AM
M-benz's Avatar
Lets just if the CAT was bad ..what do I need to get replace with ? OEM Honda one ? Man I bet it would be pricey . Any other brand that you can guys recommend ? I kinda still confused when the code says bank 1 but its not necessary mean O2 sensors hmm ... How do I check the CAT to know if its bad or not ? We don't have smog check here so can I just run w/o CAT but the CEL is still on ?
Old Oct 1, 2013 | 04:57 AM
M-benz's Avatar
You lost me buddy
Old Oct 1, 2013 | 01:14 PM
thewrai6th's Avatar
http://bigdaddiesgarage.com/angled-cel-fix-real.html
Old Oct 1, 2013 | 01:36 PM
TunerN00b's Avatar
Any legal cat will do.
OEM Honda one ?
No.
What is there to be confused about? If you don't understand what a catalytic converter does, or how it's performance is monitored, then stop wasting time on here and take it to a professional.
First, with a visual inspection. Followed by using a pair of wideband O2 sensors if need be.
If you're willing to break the law (doesn't matter if you have a smog check or not, it is a federal requirement) and don't care about either the environment or anyone around you, and don't care that you will be giving up your early warning for engine issues (CEL becomes useless when always on), and are ok with the increase in volume and raspiness of the exhaust from using a test pipe instead of a cat, then yes. Otherwise, just put a working cat on the damn thing.
Old Oct 2, 2013 | 06:04 PM
M-benz's Avatar
Yes sir lol
Old Oct 7, 2013 | 05:26 PM
edc056394's Avatar
Just had the same code replaced the cat and no more light
Old Oct 7, 2013 | 05:34 PM
M-benz's Avatar
May I ask what type of cat did u replaced if u don't mind I'm asking or maybe a part # so I can order one ?
Old Oct 10, 2013 | 06:33 PM
M-benz's Avatar
What do you guys normally replace with ? Maybe a part # would help ...
Old Oct 11, 2013 | 05:12 AM
tamboo's Avatar
10 Year Member
these fit 95, probably some others. search your model to double check.
http://www.rockauto.com/catalog/x,ca...,parttype,5808
or if you have a large bank account:
http://www.acuraoemparts.com/delray/...RA__CONVERTER#
Old Oct 11, 2013 | 02:00 PM
M-benz's Avatar
I found this on eBay ...what do u guys think ? It should fit w/o any modification according to their description !!!
http://item.mobileweb.ebay.com/viewi...d=170471587691
Old Oct 12, 2013 | 07:42 AM
tamboo's Avatar
10 Year Member
looks too brand x imho.
personally i'd spend a bit more for the eastern catalytic model
since it has the little <3 next to it = most purchased.
they could be made by the same chinese factory tho, who knows.
http://www.rockauto.com/catalog/more...972&cc=1000382
94 IntegraLS
Oct 4, 2010 05:38 AM
B16AGUY
Nov 18, 2008 06:39 AM
zeBRAHz
17
Nov 14, 2007 11:56 AM
elpiar
May 8, 2005 09:37 AM
Two_K Si
Oct 13, 2004 08:32 PM
