96 honda accord v6 2.7 power steering problem
Old Sep 27, 2013 | 09:54 AM
hfbellosa's Avatar
Default 96 honda accord v6 2.7 power steering problem
when ever i turn the wheel left or right reverse or forward it sound like the power steering fluid is low, but when i check it its at max. could the power steering pump be going? please help.
Old Sep 27, 2013 | 06:37 PM
goukiteg's Avatar
Default Re: 96 honda accord v6 2.7 power steering problem
You'd probably get more help here https://honda-tech.com/forums/forumdisplay.php?f=2
This is strictly an appearance forum.
Old Sep 28, 2013 | 12:07 AM
holmesnmanny's Avatar
you could buy a power steering build kit and rebuild your pump...they only run about $10 or so
Old Sep 28, 2013 | 10:20 AM
zuvy's Avatar
Check the supply hose from the reservoir as well; they get hard and can crack or leak air into the system. If you rebuild the pump do yourself a favor and replace the front bearing and ALL the seals and o-rings.
Checkers
Jan 7, 2019 05:20 PM
Blonby
Dec 12, 2018 07:08 PM
1sgranger75
Nov 14, 2014 08:09 AM
Kuffs
Dec 19, 2011 08:42 AM
