Question on removing the drivers side lower motor mount
Old Sep 27, 2013 | 07:53 AM
98ITRAgain's Avatar
Default Question on removing the drivers side lower motor mount
I am getting ready to install all the A/C parts I have gathered/ordered from Honda, and would like to remove and paint the lower motor mount/A/C mount before installing everything.
The service manual goes over removing it; but does not say anything about needing to support the motor. I do not want to put a lot of stress on the upper mount. Do you all usually put a jack or other support under the motor when removing the lower mount?
Thanks!
Old Sep 27, 2013 | 08:53 AM
94rs-turbo's Avatar
Default Re: Question on removing the drivers side lower motor mount
you can just lower the upper driver mount and be fine, if worried get a jack and a block of wood and support it under the oil pan
Old Sep 30, 2013 | 04:57 AM
98ITRAgain's Avatar
Thanks. Sounds like a good idea to support it and not put too much stress on the upper mount.
Old Sep 30, 2013 | 05:01 AM
UGAVtech's Avatar
Good suggestion...
Old Oct 1, 2013 | 05:50 PM
purplepassiongsr's Avatar
I just jacked up at that lower brace
Old Oct 3, 2013 | 12:07 AM
GZR4DR's Avatar
The two upper mounts (trans and driver side) and rear mount are what hold up the engine. The lower mounts are just suspension/vibration mounts. No need to support the engine with a jack when replacing them.
Old Oct 3, 2013 | 05:10 AM
pennies_hatchie's Avatar
correct.
97C1V1C
Sep 14, 2010 07:44 PM
obuhmyuh
26
Nov 5, 2008 02:30 PM
bunske123
Oct 10, 2007 10:50 PM
komat
Dec 13, 2005 09:48 AM
