Best adjustable cam gears?
Old Sep 26, 2013 | 07:54 PM
mkeacura's Avatar
Post Best adjustable cam gears?
I dont know much about adjustable cam gears but I've been looking to buy a set this week.
Does anyone have any suggestions for which brand and size I should buy for b18c1?
So far i have header, test pipe, 2.5 exhaust, short ram, intake man, underdrive pulley kit....also on the list soon, fuel injectors (once i figure out which ones i want)
Old Sep 27, 2013 | 08:29 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Best adjustable cam gears?
They all do the same thing...advance/retard timing. Buy whatever you want...
From your short list of mods, having adjustable cam gears won't do a damn thing....
Old Sep 27, 2013 | 08:35 AM
kyden's Avatar
any reason why you think you need it or injectors? golden eagle I feel has the best gears on the market.
Old Sep 27, 2013 | 12:07 PM
B_Swapped93's Avatar
waste of money even with entry level cams it still is you're no where close to needing them.
Old Sep 27, 2013 | 12:11 PM
Black R's Avatar
25 Year Member
Best?
ST Corsa.
Those are almost impossible to find, and no you can't have mine.
If you like vernier scale, then Toda.
If you're cheap, them skunk2.
If you like rare Jdm ****, then Asport.
Old Sep 27, 2013 | 08:56 PM
mkeacura's Avatar
what would u recommend i do next?
mkeacura's Avatar
same question as ^^
Old Sep 27, 2013 | 09:00 PM
Originally Posted by mkeacura
same question as ^^
what ?
Get cams that require/benefit from adj cam gears....in other words highcomp N/A OR TURBO....pick your route
Old Sep 28, 2013 | 12:09 PM
mkeacura's Avatar
what ?
what i meant was, what do u recommend i do next? if i dont need cams yet, what would u suggest i do next?
Old Sep 28, 2013 | 04:20 PM
You''ll need a higher compression engine something like 12:5:1 or above but that isn't cheap, you could also turbo the car.
Old Sep 28, 2013 | 04:39 PM
mkeacura's Avatar
Turbo it before i do internals? bottom and top
Old Sep 28, 2013 | 04:44 PM
low comp pistons for turbo. High comp pistons for N/A. there are turbo specific cams out there afaik gsc makes them then there's a benefit possibly but the hang up on adj cam gears is not needed I was like that at first then started speaking regularly with my tuner. Have learned LOTS talk to someone who knows their **** it's well worth it.
Old Sep 30, 2013 | 03:10 AM
NVturbo's Avatar
O.G. triple O.G.
An alarm (if you don't have one already).....
a set of camshafts.
Hdeucedeuce
18
Mar 21, 2012 03:47 PM
h22_crx
Oct 26, 2005 11:10 PM
B18Redline
Nov 29, 2004 10:24 AM
roadawg
44
Feb 11, 2004 08:59 AM
Red Rocket
Feb 11, 2002 05:10 PM
