Low RPMs, and VTEC help!!!
Old Sep 25, 2013 | 11:56 PM
xLokei360's Avatar
Default Low RPMs, and VTEC help!!!
No CEL's and seems to be in limp mode. When gaining speed, it always shifts at about 2500 RPMs and wont go any higher then 3500 even in 4th gear (Automatic Tranny). Also was trying to figure out why the VTEC wasnt engaging and heres the problem, not connected. Another problem, theres no where to connect it on the ECU (PS9 - obd0). So basically I need to know why im in limp mode, and if theres a way to wire the wires from the celinoid to the ecu without breaking anything, or if I can connect the celenoid directly to a switch. Thanks for reading and feedback would be appreciated.
Celinoid with wires coming out and into the interior of the car-
Ecu, with the celinoid plug not plugged in. (Red cap).
Vtec controller, not sure if this will help-
The switch I could connect it to-
Car info-
1990 Honda CRX DX.
Automatic D16A7 VTEC.
Old Sep 26, 2013 | 12:25 AM
rd91sib18c5r's Avatar
Default Re: Low RPMs, and VTEC help!!!
I don't know about your vtec set up, but the tranny you can adjust the kick down cable
it should help it shift at higher rpms.
Old Sep 26, 2013 | 12:32 AM
xLokei360's Avatar
Can you maybe show me a link with picture with how to do that? or explain to me.
mc_yen
Mar 4, 2010 07:07 PM
94eg'n
Sep 24, 2007 04:09 PM
SPEracing
Mar 8, 2004 06:50 PM
jaydm98
16
Jun 8, 2003 11:18 AM
