screeching noise back axle
Old Sep 25, 2013 | 11:31 AM
'97 RS Teg's Avatar
Default screeching noise back axle
Hi, I have a 1997 Integra type rs. I have a screeching noise coming from my back tire but only when I'm moving and Turing a certain degre. I cant seem to find the noise. Amy help is appreciated. My back wheel was replaced. Hit black ice bent it on a curbe. Had to get a new wheel and a hub stud was sheered right of. Not sure if its coming from this
Old Sep 25, 2013 | 11:41 AM
fcm's Avatar
fcm
Old Fart
Default Re: screeching noise back axle
Check the brake splash guard, make sure it is not loose or bent also make sure a stone or something has not got stuck between it and the disk.
Also check the bearing. 94
Old Sep 25, 2013 | 04:36 PM
'97 RS Teg's Avatar
I recently checked to see if anything I could see anything rubbing around my wheel. But when I jack it up it doesn't make the noise no matter how much spin the wheel. It only makes the noise while im driving. It goes on and off when I change lanes. If get on a slightly curved road it will stop from the pressure.
Could it be a bent rotor is slightly bent?
Old Sep 26, 2013 | 06:00 AM
fcm's Avatar
fcm
Old Fart
You would think if the rotor was "bent" you would hear it all the time, even up in the air.
Does stepping on the brake a little when the noise is there change anything? 94
Old Sep 26, 2013 | 12:18 PM
'97 RS Teg's Avatar
That's a good point.
Yeah I ez on my brakes it goes awa. Its barley makes this noise as low speeds aswel.
I changes my brakes with in the last 500 miles.
curvenut
Jun 17, 2014 12:32 AM
sSandstorm
May 20, 2013 12:19 PM
Geoshanna
May 20, 2013 07:27 AM
vigorhy
Mar 20, 2008 03:54 PM
Lude Acts
Jan 24, 2008 05:25 AM
