help with High Beams please
Old Sep 23, 2013 | 08:11 PM
xesvuli420's Avatar
Default help with High Beams please
Far from home, no multi meter, both high beams just suddenly stopped. both 10a fuses under the dash are fine... anyone?
Old Sep 24, 2013 | 04:59 AM
TheRealTegger's Avatar
Default Re: help with High Beams please
Year, make, model???
Old Sep 24, 2013 | 10:39 AM
fcm's Avatar
fcm
Old Fart
If the fuses are good, it is either the bulbs or the dimmer switch.
Do you have flash to pass, does high beam indicartor in cluster turn on? 94
Old Sep 24, 2013 | 12:28 PM
elmanre's Avatar
Could be the switch...
Old Sep 24, 2013 | 12:55 PM
xesvuli420's Avatar
Indicator does work
Is there not a relay somewhere?
Hard to believe its the bulbs since both went out at 1 time
Old Sep 24, 2013 | 03:46 PM
fcm's Avatar
fcm
Old Fart
There is no relay for high beams, and the indicator in the cluster is after one of the high beam fuses, meaning the switch is good.
I would check the bulbs and test the bulb socket.
What is the MM&Y of the car? 94
billybod
Jun 21, 2019 09:55 AM
Kimbo
Jan 18, 2011 08:41 PM
Cashieboi
12
Mar 1, 2008 08:44 PM
hookem51
Honda Civic (2001 - 2005)
May 4, 2007 06:25 PM
jadugartir
Apr 28, 2005 04:35 AM
