Ls Help
Old Sep 23, 2013 | 04:38 PM
JohnCandy's Avatar
Default Ls Help
OK I know theres many forums on this but this is my 1st swap and Im lost. I have the obd0 to obd1 ecu jumper ordered and on way but my concern is that do I need the obd1 cabin harness or will the jumper take care of that?
Old Sep 23, 2013 | 05:01 PM
Freemananana's Avatar
Default Re: Ls Help
First post.
But here's some help.
No. You don't need a cabin harness.
You get a jumper harness, obd1 distributor, and an appropriate ecu.
Please search though. You aren't the first person to try this, it's in the FAQs. Reading a right up will help you more than 30 threads on here.
Old Oct 2, 2013 | 12:28 PM
JohnCandy's Avatar
Default Re: Ls Help
ok so now Im running into a problem with the shock tower plugs, Im new to b swaps
Old Oct 6, 2013 | 04:46 PM
94EG8's Avatar
Seagull Management
Default Re: Ls Help
What exactly are you trying to do here? If you're trying to use an OBD0 integra harness then no that wont work ('92 - '93 wont either)
Old Oct 13, 2013 | 06:04 PM
JohnCandy's Avatar
Default Re: Ls Help
im going obd1 and Im trying to figure out if I need stock harness to run from shock tower to shock tower or? iv read forum after forum and im still confused
Old Oct 13, 2013 | 07:08 PM
94EG8's Avatar
Seagull Management
Default Re: Ls Help
What car (make/model/year/trim) and what engine exactly?
Old Oct 13, 2013 | 07:23 PM
JohnCandy's Avatar
Default Re: Ls Help
88 civc dx and B18a1
Old Oct 14, 2013 | 03:32 AM
94EG8's Avatar
Seagull Management
Default Re: Ls Help
OBD0 or OBD1 B18A?
Old Oct 14, 2013 | 08:07 AM
JohnCandy's Avatar
Default Re: Ls Help
odb1
Old Oct 14, 2013 | 08:13 AM
94EG8's Avatar
Seagull Management
Default Re: Ls Help
You'll need the conversion harness and you'll need to convert to MPFI, change the distributor plugs and do a few other things that escape me at the moment.
Old Oct 14, 2013 | 08:41 AM
JohnCandy's Avatar
Default Re: Ls Help
I have the ecu jumper dfi to mpfi, ecu, integra axles, dented frame rail, dizzy adapter
V-tec_91_Hatch
Dec 3, 2012 12:18 PM
motoguy126
Jul 26, 2010 09:43 PM
8YourV8
Jan 3, 2007 09:49 AM
turbotime.
20
May 25, 2003 11:52 PM
