F20b motor M2B4 Tranny Clutch Set that will fit.
Guys I've been looking around and google, I can't seem to fine a clutch/flywheel set that will fit the F20b motor, and I got a M2B4 tranny which is a 92 to 95 JDM Prelude. I've check on ebay and ask question, message me back tell me that their customer said that it's the same as a H22 and H23 clutch set. Can someone help me Thanks,
I really need my car, it won't go into gear when the car is running but will when the car is shut up.
Just me....sounds more like a bad slave or master than a clutch issue. Again just me and I know nothing....but go ahead and replace the clutch, if your are going to do that....get a new flywheel or have yours re-surfaced. While there, I'd put a new rear main seal in it as well......your are looking right at it, do you want to do all that work again just to replace the seal later?
