What clutch is this?
It was suppost to be a stage 1 exedy for 94+ integra but it doesent look the same, I got it online from somebody. I'm not sure what it is, only markings on it is on the back of the pressure plate it says 1190700. I might just sell it cheap and take a loss or might try to run it I'm not sure, any help would be appreciated thanks.
that's not an exedy pressure plate. the stage 1 & 2 share the same pressure plate which can be seen here
http://www.turboinstall.net/general-...lutch-install/
also notice on the stage 2 you can see the exedy daikin wings stamped on to the hub
i have no idea what clutch that is but it's not an exedy stage 1
probably just a general oem replacement from the auto parts store, doesn't really look like a bad clutch, has decent springs in it.
the exedy 1's are only 250 new online, not sure why you would take the risk over so little money. most people selling parts for these cars are liars and dirtbags. unless you know exactly what you're looking at only buy from authorized dealers
yea I just called the guy back and he wont take it back, I told him its not what he said it was. I ended up tellin him off cause he lied about it, I paid 160 for it so yea im not sure I might just sell it for 100 or somthen.
mistake 1 was buying a part you didn't know how to identify
you will have a hard time getting $100 for that clutch. a full exedy oem replacement clutch kit with a new throw out bearing is only $100
if it's actually for a 94+ integra i would just run it and call it a lesson learned. did you get the pilot bearing and throwout bearing as well?
the exedy oem also uses a pressure plate that looks just like the stage 1 and 2, just has less clamping force and thinner everything
the disc would also have the exedy symbol stamped on it
if i made a wild *** guess i would say it was either
1. some off brand a dude found on ebay
2. an auto parts store special from orileys or vatozone
ahh, i think i found it http://www.ebay.com/itm/AMS-AUTOMOTIVE-08-026-Clutch-Clutch-Kit-/321171673573?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AIntegra&hash=item4ac752d1e5&vxp=mtr
looks identical
ahh, there's a OE fuji carbon disc. every one i have ever seen has those wavey little do-dads in the metal. no other clutch i've came across has those
kind of rare really, people usually don't pony up the cheddar to buy those and i'm fairly sure fuji does not sell those direct, you have to buy them from honda/acura as an oem part number
