odd starting problem and out of ideas
Old Sep 22, 2013 | 05:01 AM
dapps's Avatar
Default odd starting problem and out of ideas
hello, i have a 91 accord dx and been trying everything to figure this out.
i can turn the key and crank all day but it dont fire at all, i can let off and
crank again and it will fire but not start, i can let off and crank again and it most of the time starts on 3rd time if not fourth time.
new parts are : main relay,new honda distributor, iac,high idle,ecm,fuel pump
also did some wiring repair on wires under floor around computer area.
Old Sep 22, 2013 | 10:39 AM
lazlong's Avatar
Default Re: odd starting problem and out of ideas
-Spark plugs? With correct gap?
-Injectors need cleaning or replacing?
Old Sep 22, 2013 | 05:46 PM
dapps's Avatar
yes i did that also.
Old Sep 22, 2013 | 06:35 PM
lazlong's Avatar
Does it run ok after it starts? Kinda sounds like a fuel delivery problem. How many miles on the engine? May just be geting old and worn out. You take care of them but, their just a machine and machines wear out eventually, no matter what you do.
Old Sep 22, 2013 | 10:16 PM
holmesnmanny's Avatar
Test the engine coolant temperature sensor. Just do a search for instructions.
Old Sep 23, 2013 | 02:10 PM
dapps's Avatar
THANK YOU I'LL TRY THAT AND RESPOND
highazamotha
Feb 17, 2015 12:53 AM
sohcrx91331
Feb 2, 2010 11:58 AM
zrs6v4
Jun 16, 2009 11:35 AM
sf@rx7
Feb 22, 2009 11:34 PM
stdefhatch
May 6, 2006 01:54 AM
