Accord Intake Issues
I have a 2000 Honda Accord and every time I put in an aftermarket short ram intake in the car, it only starts when it's cool. If I go run an errand, and leave the car sitting for 20 mins, the car won't start. I'll have to wait for it to cool a bit before it will start again. It has this problem with both a cheap intake from say Autozone and Expensive ones from AEM. I've cleaned the entire intake system, checked for any fuses, eliminated it being a fuel pump issue, and replaced the main relay. If I put the stock intake in the car, it works just fine with no issues. Could it be the hoses going into the intake? Maybe it's not creating enough of a vacuum when I use an aftermarket intake?
Any ideas?
Any ideas?
What do you think the problem could be? Like I said, it runs fine with the stock intake, but for this to occur with two aftermarket intakes, the problem would be something with the intakes.
