92 eg hatch won't run. Please help!!!
Old Sep 21, 2013 | 10:21 AM
Beerye1089's Avatar
Icon2 92 eg hatch won't run. Please help!!!
I was recently given a hatch with a d15b2 block, pm9-8 head p05 computer and it has the smaller intake out of the vx/hf. It is a 5 speed. It gets spark with the plugs out of the block and attached to the spark plug. But with everything together and spraying starter fluid in it it doesn't even try to fire. The only code it's throwing is 16. Fuel injectors. I've tested them and they seem to be working right. If I'm getting fuel and spark why won't it crank? Timing also seems right as far as cam gear and rotor button. I've seen this car run before. It ran good. Just died on the previous owner so he gave up on it. Anybody have any suggestions?
Old Sep 28, 2013 | 06:43 PM
b18C1CouPe's Avatar
Default Re: 92 eg hatch won't run. Please help!!!
I'd run a compression test to see if the motor is still healthy.
Old Sep 29, 2013 | 09:51 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^, you need spark, fuel and compression for an engine to run.
Also checking spark the way you did is not correct, spark "acts" much differantly under pressure, pick up an HEI spark tester, they are not that expensive...
https://www.google.ca/search?rlz=1T4...O4f4yAGw5oHoBQ 94
Old Sep 29, 2013 | 04:53 PM
b18C1CouPe's Avatar
harbor freight has an inline spark tester for 4 bones. i have one and it works great.
Old Sep 30, 2013 | 04:05 AM
ls/vtecek9's Avatar
X2^
tchandarlis
Sep 6, 2016 09:33 PM
Beerye1089
Sep 25, 2013 04:52 PM
Maidumechanic
Feb 14, 2013 05:39 AM
Ek9_Cuhzz
58
Jan 7, 2011 04:54 AM
H22FAN
Mar 25, 2004 02:16 PM
