Honda CR-V & Element 2WD & 4WD Element & CR-V
Help with power accessory socket rewire
Old Sep 21, 2013 | 04:05 AM
Daghda's Avatar
Default Help with power accessory socket rewire
I have a 2013 and I tow the car. Honda manual recommends that I pull the #19 fuse under the dash, for long day towing. I set up a switch for that fuse, but if that fuse is shut off, the accessory/lighter sockets are also shut off. I need power to one of the accessory sockets with the key on acc.
The #19 fuse forth over from the left on the fuse box ( row two down ) is rated at 7.5 amp and labeled ACC.
Is there a relay I can jump out or another socket that will work only on acc I can rewire the socket to?
Or am I better off just installing another socket direct to battery?
Another related question: Is there anywhere I can see electrical diagrams without buying the service manual?
Old Sep 21, 2013 | 06:17 AM
PhilStubbs's Avatar
Default Re: Help with power accessory socket rewire
If it was me, I would just wire up a second outlet.
osbunjosh
50
Jan 29, 2024 05:20 PM
Crocky
Apr 19, 2017 11:03 AM
crxd88
Engine Management and Tuning
Dec 6, 2014 05:12 AM
GotGSR
Sep 2, 2004 08:59 AM
cd5_2NR
Audio / Security / Video
Jul 1, 2004 01:38 PM
