jdm f22 sohc non vtec into 96 accord(misfire)
im getting a random misfire code. i've replace sparkplugs/wires/dist/(its internal coil conversion) i've correctly ran the ckp,tdc sensors to the new internal coil dizzy. i am using the jdm intake manifold/fuel rail and dont have access to my 96 intake manifold at the moment. My question is..
Was i suppossed to swap my 96 manifold and fuel rail to the obd1 jdm motor?
Are the injectors different?
Have you checked the EGR manifold and ports are free and clear of carbon build up and soot?
If the EGR ports are plugged there will be a lean misfire.
the vtec has an internal coil while the nonvtec is external coil...without any other real information based on what exactly you are trying to do I'm not sure how anyone is supposed to help you
Both manifolds have egr on it. the usdm and jdm one. Ive read somewhere that the injectors are different and i would need to either use my usdm fuel rail or buy an obd2 to obd1 adapter. Im confused because the obd2 plugs currently on the car plugged right upto the jdm injectors without any midifications. I ONLY misfire on the highway above 60 mph which leads me to believe its fuel related
RA050224
Sep 26, 2005 12:18 PM
Luiyo
May 25, 2004 08:21 AM
