Accord 92 intermidiate axle
Old Sep 19, 2013 | 11:16 AM
Honda cd65's Avatar
Default Accord 92 intermidiate axle
Hi there - have a Accord 92, - after removal of left driveshaft, - should there
be any play up and down at the intermidiate axle attached to the engine?
Thanks in advance!...........
Old Sep 19, 2013 | 10:31 PM
holmesnmanny's Avatar
Default Re: Accord 92 intermidiate axle
i have play in mine and I just haven't had a chance to go down to the junkyard and pull another intermediate shaft...there definitely shouldn't be any play where the axle enters the intermediate shaft. Mine currently makes a clunk sound when I stop and go. It just started doing this lately. When I went under to check and feel for what the issue was I wiggled that particular spot and saw the play.
i'm debating whether to take my old one apart to see what the issue is after i pick up a used one...if i do i will update this thread...gonna do it in a couple days or so
Old Sep 19, 2013 | 11:55 PM
Honda cd65's Avatar
Mnnnnn thanks holmesnmanny,- yeah got that clunk noise too at stop and go
and especially when turning right. - When turning hub the inner joint sightly
moves up and down.......Is the inner bearing only retained by the circlips or
pressed into the engine bracket?
Old Sep 20, 2013 | 04:18 AM
it's pressed in and held by a circlip...looking at my helms i'm guessing the bearing is bad
creativename
Dec 6, 2015 03:20 PM
kngkong1256
Feb 16, 2010 06:52 PM
MNMike
Dec 11, 2009 04:48 PM
chunsa
Apr 15, 2007 10:03 PM
B18CUL8R
Jun 5, 2004 03:10 PM
