'91 Accord DX ignition problem
Old Sep 19, 2013 | 04:43 AM
Alabass's Avatar
Default '91 Accord DX ignition problem
I have a '91 Accord DX 5-speed, fuel-injected. I recently drove it to work, no problems. When I got ready to leave work, starter would not even click. Push started it and drove it home. Got home, starter still would do nothing. Radio, lights, a/c, everything else still works fine. Checked all fuses and relays, nothing burned out. Pulled starter, had it tested and it's ok. What else do I need to check? Could it be the ignition switch itself? Like I said, everything else works, just can't get it to crank. Thanks.
Old Sep 19, 2013 | 07:58 AM
Joyboy's Avatar
Default Re: '91 Accord DX ignition problem
Those years are notorious for the little plastic plug breaking and the clutch interlock switch does not know you have the clutch pushed in. So it won't let you start the car. Here is the relay test and that switch I'm talking about. Replacement plug is like $3....
File Type: pdf
MayDayTegGS
Aug 26, 2012 08:30 PM
Celendil91ACC
Mar 11, 2011 10:21 AM
hondastrtracr
Sep 29, 2007 04:27 AM
KAOS-Rider
Aug 16, 2007 11:08 AM
JimKW
Sep 20, 2005 10:37 AM
