H2B del sol. fs/ft
Old Sep 18, 2013 | 12:48 PM
crx6662's Avatar
Default H2B del sol. fs/ft
i have my 1994 del sol si up for sale or trade.
PLEASE READ THE INTIRE AD BEFORE YOU ASK ME QUESTIONS.
body:
integra wing.
carbon fiber rear bezel.
97 front end.
clean zero rust (still has factory weather stripping under rear wheel wells)
carbon fiber hood.
135xxx original miles.
DOHC V-Tec decals on both sides.
wheels, suspension and brakes:
rota sub zero's 15"
pink blox extended lugs.
5mm wheel spacers up front (to clear brakes)
wilwood big brake kit up front. drilled and slotted rotors. steel brake lines. 4 piston calipers.
type r rear disk brake swap. steel lines.
ohlins full body coil overs (type-r) 30 way dampening. (best suspension i've ever had)
blox upper control arms. adjustable.
function7 LCA's (type-r style to make suspension fit)
type r rear sway bar.
energy suspension master bushing kit. pretty much every bushing on the car has been replaced with energy suspension.
both lower ball joints up front have been replaced in the last 2 months.
new driver side front wheel bearing.
type-r front sway bar.
motor:
h22a1 long block.
pro series intake mani.
pro series 70mm TB.
RC 440cc injectors.
aem fuel rail/fpr w pressure gauge.
3" intake.
PRM Try-Y H2B header.
full 3" stainless exhaust.
97 spec type-r LSD trans (B series)
evolution H2B master kit (hasport mounts, evo plate. evo flywheel, evo half shaft. evo pcv.
evo slave adapter. evo extended fork.
act 6 puck un sprung clutch.
bradded steel clutch line.
fluidyne dual core full size radiator/ slim fan.
brand new axles this week.
type-r shift linkage and shifter.
MSD external coil, dizzy cap, rotor, wires.
walbro 255.
interior:
97 interior. (dash, center consol, seats)
3" offset 6 bolt steering wheel.
clean interior, driver seat has a small rip.
mp3 cd player.
RF amp to power the interior speakers, no subs.
battery re located behind passenger seat.
engine bay:
the bay was painted light blue, then splattered with pink, green, yellow and white.
semi tucked bay.
red valve cover off a jdm h22a.
trans is painted.
a lil about the car. it runs and drives great. just got it off the dyno for a tune it put down 206whp and 170 torque on 91 octane pump gas.. rev limit 7,500 cel shift light at 7,100 2step at 4,000.
was on a dyno dynamics not all the way corrected so the actual whp is a lil more. right around 215whp.
even with lsd trans, it gets no traction 1-3. its a blast to drive. stays dead nuts/pulls on with k swapped eg's.
tuned by Curt Miller at Dynotunedperformance in Middleton WI
now for the dreaded bad list:
no wipers/ motor assmbly.
no heater core/climate controls. (no heat and no ac)
cf hood is cut up underneath to get the hood to shut. since with h2b it ***** the motor forward and makes hoods not like to close worth a ****.
this car was gutted when i got it, was a weekend track car.
can only lock/unlock the doors from the outside with the key. (to prevent someone reaching in to unlock the doors. can be re hooked up with door panel off)
other than that every thing works as it should, windows, blinkers/lights ect.
i am looking to trade my del sol for another honda, swapped and clean would be nice. im defiantly not gonna trade for a rusted sohc, unless you got deep pockets to throw my way also. so keep that in mind. my car is not perfect, but it is in great shape for the year/setup.
would also sell for the right price, looking at offers. shoot me a text 608-295-9590
ill work on getting some pics up....
Old Sep 18, 2013 | 12:51 PM
crx6662's Avatar
Default Re: H2B del sol. fs/ft
this pic is right before the engine bay was painted and the motor was swapped:
Old Sep 18, 2013 | 01:23 PM
crx6662's Avatar
Old Sep 19, 2013 | 08:08 AM
rayvo's Avatar
bump for you sir.. and a sol with some flavor. Seen that teal hatch running a high 13 @gld and he laughed at my 15 flat singlecammer lol
Old Sep 19, 2013 | 04:36 PM
kings**t's Avatar
Nice car I rember mine loved the back window
Old Sep 20, 2013 | 08:38 PM
crx6662's Avatar
thank you!
he was on junk radials and a open diff. he got a 12.9 finally at cordova few weeks back. his car is so much fun to drive for being stock k
TTT!
Old Sep 23, 2013 | 03:06 PM
Fibercation's Avatar
Looks good check my threads....i have a eg h22 hb maybe your speed
Old Sep 25, 2013 | 01:03 PM
crx6662's Avatar
ttt
Old Oct 1, 2013 | 04:30 PM
crx6662's Avatar
bump
Old Oct 3, 2013 | 08:59 PM
crx6662's Avatar
come winter id be willing to sell the h long block, pro series intake, pro series tb, rc injectors. blah blah all the good stuff. h2b kit. pretty much a full h2b swap minus trans. im gonna do just b swap. will include tuned ecu 210 whp 170tq motor put down. can come get a ride in the car before its pulled to ensure it runs strong and has no problems. that wont be for a lil while yet (soon as weather gets cold, buying a forester this weekend for winter car so del sol will be parked) just to see if anyone has any interest in it.
Old Oct 16, 2013 | 10:08 AM
crx6662's Avatar
ttt
Old Oct 17, 2013 | 04:14 AM
kings**t's Avatar
what would you be looking for the swap?
Old Oct 18, 2013 | 08:55 PM
crx6662's Avatar
not to sure what to ask for it. not a super common swap being sold i guess. not to sure. or id trade my swap for a b series long block. and keep my trans. or for right price sell my whole swap with the trans h2b kit. everything...
Old Oct 25, 2013 | 02:33 PM
crx6662's Avatar
up
Old Oct 28, 2013 | 06:09 PM
rayvo's Avatar
bump
Old Oct 28, 2013 | 07:54 PM
ky-jelly's Avatar
kool...digging the bay...glws
Old Nov 12, 2013 | 01:50 AM
crx6662's Avatar
thank you, car is in storage for winter. may be back up for sale in spring if i don't decide to keep it. CAN DELETE THREAD.
Old Nov 17, 2013 | 06:58 AM
DelSolMike's Avatar
Very nice sol. Quality parts. I really dig the build. Good work!
If that motor were in any other civic I would buy it in a second. I don't need another sol....
Old Nov 17, 2013 | 09:05 PM
angryhillbilly's Avatar
nice looking car. GLWS
Chive On brotha
Old Nov 30, 2013 | 01:30 AM
crx6662's Avatar
just sent you a pm, saw your wanted thread. didn't realize you already saw my car lol
Old Nov 30, 2013 | 04:27 AM
How it shoupd be........i have a h hatch if interested
Old Nov 30, 2013 | 06:45 AM
crx6662's Avatar
thanks man, if i get rid of this I'm gonna be looking at something newer. i have my 94 ex sedan still. so ill always have some sort of civic. but id like to get a newer rsx, or maybe even not a honda for a change. i probably wouldn't be interested in anymore H swapped cars haha I've had to many of them.
Old Nov 30, 2013 | 06:55 AM
DelSolMike's Avatar
Put that motor in the 94 sedan (if it has no rust) and Ill take it.
Old Dec 2, 2013 | 10:51 PM
crx6662's Avatar
i was thinking about doing that this spring to be more of a sleeper. but the sedan has bondo and its more of a daily (207xxx) miles on her. runs and drives like its brand new tho lol.
Old Dec 3, 2013 | 07:52 PM
mien_civic715's Avatar
trade
http://wausau.craigslist.org/cto/4185365670.html
