Honda CR-V & Element 2WD & 4WD Element & CR-V
After market clock
Old Sep 17, 2013 | 08:39 PM
JLPhelan's Avatar
Default After market clock
Any recommendations for an after market clock for my 2000 CRV or should I just try the dealership? Not looking to spend too much, just want something that works better, the clock seems to dim and brighten on its own with no pattern right now.
Old Sep 18, 2013 | 02:47 AM
CarGuy91's Avatar
Default Re: After market clock
it's actually a simple fix. there's a couple write-ups around on how to do it. basically theres 2 parts on the circuit-board (resistors i think) that statt coming loose and if you resolder them, the clock works fine again. otherwise, if you dont want to fix it, guys sell them on ebay for like $20-$30
Old Sep 18, 2013 | 03:07 AM
PhilStubbs's Avatar
The fix is simple, but even properly working, the clock is dim. It's ok at night, but useless during the day
Old Sep 18, 2013 | 06:10 AM
boliviansol's Avatar
Just use ur stereo clock - problem solved
Old Sep 18, 2013 | 06:24 AM
JLPhelan's Avatar
Thanks everyone, I think the resistor came loose on my fan **** as well. I'll have to crack it open and check them both.
Old Sep 18, 2013 | 08:29 AM
PhilStubbs's Avatar
If your fan stopped working on lower speeds its the resistor mounted in the fan box. Pull the glove box and its right there with 3 wires in the plug
Old Sep 18, 2013 | 09:13 AM
kiseliok's Avatar
http://blog.scurker.com/2010/09/hond...2001-clock-fix
Old Sep 19, 2013 | 05:17 PM
squeaks's Avatar
Thank you, I just did this earlier and my clock is working for the first time since I bought the car.
Old Sep 19, 2013 | 09:58 PM
blk1stgen's Avatar
going to try this trick to see if it works
Old Sep 20, 2013 | 04:52 AM
kiseliok's Avatar
Yep. I'll try to do this over the weekend.
Old Sep 20, 2013 | 05:30 PM
ap1jnky's Avatar
It works .. but the clock is just **** to begin with
ekillah
May 20, 2008 02:11 PM
owlvend11
May 20, 2007 08:34 AM
ef_you
32
Jan 12, 2005 12:47 PM
whackassfawker
May 30, 2004 09:35 AM
AGPSuperstar
Feb 7, 2003 03:35 PM
