Question about axles for Innovative B series mounts/EF swaps
Old Sep 17, 2013 | 05:03 PM
James89DX's Avatar
Default Question about axles for Innovative B series mounts/EF swaps
I've searched pretty extensively and can't seem to find a definitive answer except to "buy innovative swap axles". Either this is too basic of a situation, or B swaps aren't all the rage anymore. All the threads are OLDDDDD with a lot of assumptions, but no fact.
Innovative didn't seem interested in telling me what OEM combo would work - they want me to buy their swap axles (understandable).
I would love to do that, but I'm trying to do this on a budget.
91 EF. Innovative Steel B swap mounts. B20. Cable DA trasmission w/intermediate shaft.
Can I use DA axles? DA axles with the dust rings removed from the hubs? Need advice!
I found a few threads saying that DA axles "should" work, but I want to make sure.
Thanks in advance.
Old Sep 18, 2013 | 05:42 AM
kyden's Avatar
Default Re: Question about axles for Innovative B series mounts/EF swaps
Da axles will work.
Old Sep 18, 2013 | 06:16 AM
James89DX's Avatar
Originally Posted by kyden
Da axles will work.
Thanks, do I need to remove the dust rings from the knuckles?
Old Sep 18, 2013 | 06:23 AM
kyden's Avatar
I don't see why. They don't go anywhere near the axles.
Old Sep 18, 2013 | 07:29 AM
James89DX's Avatar
Sorry I wasn't clear - I'm talking about the seal/ring on the axle side (inside) of the knuckle. It presses into the backside of the knuckle similar to an axle seal on a transmission. I've read people remove it in order to gain another 1/2" or so of clearance?
Old Sep 19, 2013 | 06:46 PM
singlecamDA9's Avatar
you're on the right path my friend. remove inner dust shield and use da axles. rule of thumb use what ever axles match the halfshaft you have.
boostedb20ek
Transmission & Drivetrain
Apr 23, 2024 08:58 PM
turboteener
Dec 4, 2008 04:16 PM
tooslohatch
16
May 13, 2008 10:42 AM
JDMotive
Aug 4, 2004 08:54 AM
