92 Civic intermittently stalls, no fuel prime
Old Sep 17, 2013 | 03:38 PM
alanartwww's Avatar
Default 92 Civic intermittently stalls, no fuel prime
This car has an intermittent low idle/stall, no-start condition. Sometimes stalls when stopping, sometimes won't restart when hot. When stalled, turning the ignition on does not produce the normal 2 sec. fuel pump prime. Starter cranks normally. After a waiting or a few ign. on/off cycles, I will hear the pump and it will start normally. An abnormally low idle seems to accompany the stalling. IACV is clean and seems to function properly. I'm suspecting a malfunctioning sensor failing to send a signal to the fuel pump relay. No CEL. Any clues?
Old Sep 17, 2013 | 03:53 PM
Former User's Avatar
Default Re: 92 Civic intermittently stalls, no fuel prime
G101 ground on thermostat housing clean and tight?
Have you resoldered the main relay?
If those are fine, your ECU may be toast.
Old Sep 17, 2013 | 06:14 PM
alanartwww's Avatar
Thanks, I'll check the grounds and resolder the main relay, but could either of those problems cause the low idle?
bigbangmtl
May 10, 2011 07:39 AM
Tatooine
Jun 27, 2010 07:00 PM
ZedEx
Jul 1, 2005 01:41 PM
cashmoneystu
Jun 13, 2004 12:26 AM
b16_madman
Jan 6, 2004 06:30 AM
