"typeR" vs "ls" oil pump
Old Sep 17, 2013 | 03:06 PM
PabloM's Avatar
Default "typeR" vs "ls" oil pump
last month i started to read about the diff between the itr an ls oil pump and ive read a looooot of threads and im still at the beginning
could anyone finally.. clear this information
is the itr oil pump touched by god? or is it the same s***?
thank you!!!!
Old Sep 17, 2013 | 03:11 PM
doood's Avatar
been there done that
Default Re: "typeR" vs "ls" oil pump
ALL 98+ b series oil pumps, non-vtec and vtec, are the SAME.
Old Sep 17, 2013 | 06:30 PM
PabloM's Avatar
ok
and what about obd0 and obd1
Old Sep 17, 2013 | 07:33 PM
doood's Avatar
there is no obd0 or obd1 type r
Old Sep 17, 2013 | 07:40 PM
PabloM's Avatar
yea but, the diff between the b16a - b17 - b18a - b18b, is there a diff between the vtec and the non vtec? wich one flows better?
Old Sep 19, 2013 | 08:17 AM
Creator's Avatar
If I remember right, b18b and b18c1 are the same. Call up a dealership and have them check, if you can find a parts guy that's not too lazy
Old Sep 19, 2013 | 03:02 PM
Sleeper EM1's Avatar
Or just look up the part numbers.
Old Sep 19, 2013 | 03:51 PM
B_Swapped93's Avatar
this is almost as bad as the guy who wanted a wanted a type r timing belt
Old Sep 19, 2013 | 04:20 PM
^Didn't they Reinforce and Lighten it?
Old Sep 19, 2013 | 04:30 PM
no i'm being 100% serious it's the same part number as the GSR one(Timing Belt #14400-P72-014 - 94-01 GSR B18C1 and Type R B18C5). a timing belt weighs like 1/4 of a pound maybe half lol same deal. from what we know OP has a tock ls engine NO need to rev past what an ls can handle and as said there is no diff from 98+
Old Sep 19, 2013 | 05:24 PM
Your sarcasm meter is broken :/
Old Sep 19, 2013 | 05:30 PM
m_shake's Avatar
It's hard to detect in text, plus you'd be surprised how damn dumb some posters here are. **** I got into a war with some douche who was certain ITR spring retainers were different and better and I proved b-series vtec all use the same part# retainer and he said just because the part # is the same doesn't mean it's the same...can't explain that lol
Old Sep 19, 2013 | 05:35 PM
This^
plus sleeperEM1 I don't know you to well around here yet, I enjoy trolling and being helpful... but most of the time ppl are so dumb I don't even want to help them
Old Sep 19, 2013 | 08:29 PM
True. I apologize.
I sometimes forget the level of stupidness on the Interwebz and forget what may also seem sarcastic is many instances are actually serious lol.
Trolling on.
Old Sep 22, 2013 | 03:09 PM
racebum's Avatar
check part numbers. i'm fairly sure but not 100% there is a vtec and non vtec oil pump for obd2. the itr/gsr pump is stamped p72 which is a highly unusual number for a b18b engine to use. even things like the oil pan are different with the itr/gsr using a p72 pan which is about 2x the cost of the b18b pan
that doesn't mean it won't fit, it just means it's not the proper part
Old Sep 22, 2013 | 06:40 PM
m4xwellmurd3r's Avatar
I just checked. All 98 integras use part number 15100-P72-A01 for their oil pumps. Thats ls, itr and gsr.
Gsr/itr pans cost more because theyre totally different. Ls pans wont fit gsr or itr blocks because of the girdle. P72 pans should work on ls blocks. Ill have to check but the pickups should be located at the same depth. More capacity too so thats good.
I think honda started using the same pumps because it just made sense to use one part for all engines. Especially something like the oil pump
Old Sep 22, 2013 | 06:44 PM
PabloM's Avatar
Old Sep 22, 2013 | 06:52 PM
B18a is low pressure nonvtec and can be easily modded to hogh pressure vtec. Obd2 pumps are all the same. Vtec and non vtec. Lower timing covers are different between 90-93 and 94+
So to use the obd2 pumps you need the late model lower timing cover.
cilvercivic
Apr 17, 2010 07:14 PM
hillbilly
Jul 19, 2009 09:47 AM
SCIVIC94
Nov 24, 2006 08:12 PM
ekVtecPower
Jun 11, 2006 08:55 AM
vtec69
Mar 3, 2005 07:45 AM
