battery light flicker high rpm b20v
Old Sep 17, 2013 | 12:22 AM
reg_lus's Avatar
Default battery light flicker high rpm b20v
I noticed that my battery light flickers ever so slightly under hard acceleration.
It starts flickering at least 5500 rpms and so on. But I can still daily without having my battery drain (no battery drain at all)
New Reman Alternator from autozone
Checked ground from alternator and is good.
Belt is tight
Harness Plug is plugged in
Battery terminal is tight
Engine: B20V B16 Head
Reman: Alternator from OBD1 b16 Delso 80amp
Old Sep 17, 2013 | 12:23 AM
reg_lus's Avatar
Default Re: battery light flicker high rpm b20v
Maybe I need a OBD1 GS-R Alternator (90AMP)??
Old Sep 17, 2013 | 02:28 PM
bks84's Avatar
Loved
probably all boils down to it being a reman alternator...
Old Sep 17, 2013 | 05:34 PM
reg_lus's Avatar
Well I took it back to do a restest and it past. took it to local shop and said it pass...so i'm lost on this...
Old Sep 18, 2013 | 07:10 AM
fcm's Avatar
fcm
Old Fart
"Flickering" Alt./Batt. light at high RPM is an indication that the alt. brushes are worn out or sticking. 94
Old Sep 18, 2013 | 07:58 AM
Runnerdown's Avatar
The voltage regulator is responsible for grounding that circuit to make the batt light come on. It's likely that the reman alternator may still function to charge the battery but have an issue within the internal regulator.
Old Sep 19, 2013 | 06:53 PM
tkhond@'s Avatar
Voltage regulator is going bad. Most shops can't check for high voltage issues only low.
Old Sep 21, 2013 | 08:59 AM
fcm's Avatar
fcm
Old Fart
Take the car to an alt./batt. shop, [Interstate batteries] and have them do a proper load/charging system test, it is free a most places and only takes a few min. 94
Old Sep 21, 2013 | 09:02 AM
TypeRfit's Avatar
RESIDENT
This.
And just because it passed a vatozone with the 2k rpm test means nothing. It might be charging at proper voltage at low rpms but overcharging (too many volts) at high rpms.
Old Sep 23, 2013 | 11:16 PM
reg_lus's Avatar
Thanks for all the help. It ends up being the alternator it self. I guess it was defective...So I had them to order me another since they were out of stock in my town. Replace and now revs without any flickering light. :D
Old Sep 25, 2013 | 12:04 AM
holmesnmanny's Avatar
It takes, on average, two autozone returns to get a good alternator.
Dj HeetazMalone
Classic Hondas
Jun 15, 2017 07:24 AM
haywyre
Oct 9, 2008 12:27 PM
ekim952522000
Jan 6, 2006 06:25 PM
fe519
Sep 23, 2003 03:25 AM
Alexnaderkeith
Sep 10, 2003 08:32 AM
