Honda CR-V & Element 2WD & 4WD Element & CR-V
crvs with built engines
Old Sep 16, 2013 | 01:45 PM
raverx3m's Avatar
Default crvs with built engines
has anyone done any kind of serious all motor builds on a crv
I was thinking how would a 2 liter vtec with a deck plate would be like in a crv
can the 4wd be locked or made into switchable to disengage the rear wheels or maybe made into a rwd only?
Old Sep 16, 2013 | 02:23 PM
Sticker Bomb's Avatar
Default Re: crvs with built engines
Well a B20 Vtec lots of people do and it makes a big difference. I'll be doing one to my wifes V at some point. Mine is just a stock 98 spec ITR engine and then boost.
Old Sep 16, 2013 | 03:16 PM
squeaks's Avatar
I have a B18c, not a whole lot done to it, just Skunk2 Intake manifold. Not a ton of torque but plenty in the upper band, Vtec and gets 33 MPG
Old Sep 16, 2013 | 03:20 PM
raverx3m's Avatar
im talking about all motor build close to 300whp will the 4wd tranny even hold up to that much power?
I bet it would be a blast to drive and smash on unsuspecting ricers and domestics
cuz crv has enough clearance to do a deck plate of any height and any kind of crazy custom intake manifold and header
so much more room in the engine bay
Old Sep 16, 2013 | 04:55 PM
PhilStubbs's Avatar
I have been at this for a very long time and I have no clue what you are getting at talking about a deck plate
You won't be able to get 300whp in any sort of streetable manner. You are better off with a mild turbo setup if you want that sort of power on the street
Old Sep 16, 2013 | 05:16 PM
raverx3m's Avatar
I said close to 300 there are few local people with daily b series with well over 250whp on their sleeved b series setups I just thought it would be insane to have that in a crv
deck plate I think its called
that raises the deck height of the block
check this thread
https://honda-tech.com/forums/drag-racing-36/look-out-b-series-350-whp-all-motor-3168721/
that motor in a crv would be insane
Old Sep 16, 2013 | 05:44 PM
You would need to but a block guard in the b20 most likely to run that kind of power the walls are to thin for that power with out one.
Old Sep 16, 2013 | 06:29 PM
raverx3m's Avatar
hell no lol im talking about decked and sleeved block with stroker kit and everythin .
the types of engines people be putting in crx and hatchbacks. would love to see a build like that in a crv
Old Sep 16, 2013 | 06:31 PM
PhilStubbs's Avatar
Once you start getting past that 100hp per liter mark you start losing street ability.
And yes, some sort of cylinder support would be needed for the b20. I'd personally go with the cncwerx CSS though over the block guard. It looks very similar but is incredibly different.
Old Sep 16, 2013 | 06:47 PM
raverx3m's Avatar
no were talking about 2 different things
deck plate adds to the cylinder length u use aftermarket sleeves.
essentially what Honda did with b16b giving it better rod/stroke ratio.
crv has enough space under the hood to do any kind of deck height without hood clearance issues
I donno about streetability. jdm ITR with boltons pushes out over 100WHP per liter
a 250whp sleeved 2 liter gsr is at 125WHP per liter and they are still reasonable daily drivers
even b16b is above 100hp per liter
Old Sep 16, 2013 | 07:04 PM
PhilStubbs's Avatar
I said "start" losing street ability. All engines handle it differently. And yea, I get the deck thing, I got distracted and forgot all about that while typing my reply. Lol. Damn ADD. :/
Old Sep 17, 2013 | 09:37 AM
Jakester9500's Avatar
I'm also intrigued by this question. Just the power limitations of the 4WD systems.
Even if it wasn't the b20b, I don't specifically care about the engine itself, just the drivetrain.
Old Sep 17, 2013 | 09:47 AM
PhilStubbs's Avatar
In N/A form I think you'd have a hard time hurting the drivetrain from just power alone. If you start drag racing and launching at the track, then you may end up with some issues. ASSuming we are talking about the manual tranny's.
Old Sep 17, 2013 | 11:56 AM
raverx3m's Avatar
yea manual. i dont see much research in this topic.
are the gears same as other b series trannys or is it the differential that is different here. maybe a custom one with some kind of locking mechanism would be good
then it will be a nice sti killer.
Old Sep 17, 2013 | 12:59 PM
PhilStubbs's Avatar
I'm sure it's an LS tranny with a transfer case added.
Old Sep 17, 2013 | 05:29 PM
qwrty's Avatar
gearing is close to gsr... somebody did post the different gearing of all Bseries tranny here before,
as for reliability.. im my expreience, almost 2years of running my V in 320hp 280tq no issues, knock on wood!
ive blown 3 b20 already w/ that tranny and transfer case... i just replace the fluids after miles
of heavy driving.. especially if its track season, i do roadcourse and autoX my V! as for auto
tranny i know somebody before who did autoX and rallyX his V before and its his real track car...
dlarsoncrv, no issues from him too...
i guess its all about the driving and driver, may be drag purpose might hurt it more than track/roadcourse...
Old Sep 17, 2013 | 05:48 PM
LDForget's Avatar
i had a built gsr in my crv with boost. Eagle rods, JE pistons, acl race bearings, ferra full valve train, arp everything, ect, ect. was running 18 lbs of boost with hondata s300 and a holset h1c big turbo.
Old Sep 17, 2013 | 05:58 PM
PhilStubbs's Avatar
Just did some research. 1st and 3rd are closer to Gsr than anything else, but the final drive and everything else is pretty far off from every other B tranny.
Old Sep 17, 2013 | 06:10 PM
Robs_B18c's Avatar
Here's my buddies crv with a Jdm b18c, skunk2 manifold, stock Jdm gsr obd2 ecu.
Old Sep 17, 2013 | 07:18 PM
raverx3m's Avatar
umm yea that engine is gonna die
1 3200lb car + towing a boat + 3/4 people and trunk full of bags + racing = engine failure.
Old Sep 17, 2013 | 08:54 PM
Robs_B18c's Avatar
Nah been running strong for almost 3 years now
Old Sep 18, 2013 | 09:26 AM
kiseliok's Avatar
yea, don't know how that thing is still running, but impressive nonetheless.
Old Sep 18, 2013 | 05:59 PM
jdm_bones's Avatar
To the OP you wont know until you try it, as for the engine the crv above hauling the boat, that shouldn't be a problem. I haul my two atv's up the grape vine about 6 times a year for the past2 years without problems and that's on a stock B20B giving it hell up the hill. My CRV is a 98' EX 4wd manual both car and engine are at 176k, i will be going to B18C after this years smog check, because I miss vtec.
Old Sep 18, 2013 | 06:18 PM
PhilStubbs's Avatar
Amount of load on the engine doesn't matter that much when the engine is basically stock with a safe factory tune. Now, put a turbo on and pull a boat, you may have an issue. It's all about an engine that can transfer combustion heat to the coolant. The more power you make the more difficult that becomes. A proper tune helps in not creating more heat than what can be dissipated.
Old Sep 19, 2013 | 10:17 AM
PrecisionPerformanceParts's Avatar
wrong, H and F series internals
