91 civic lx sedan obd0 wiring harness b20b
Old Sep 16, 2013 | 10:45 AM
Jay Jackson's Avatar
Default 91 civic lx sedan obd0 wiring harness b20b
Question ok the back of the b20 doesn't have all the sensors I need for instance there is nothing to run the fans the oil light sensor is there but I think that's it so what is everyone using to run there fans?
Old Sep 16, 2013 | 02:47 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: 91 civic lx sedan obd0 wiring harness b20b
Run the wires from the back of the block to the thermostat housing fan switch of the B20. You are planning to convert to MPFI correct?
Old Sep 16, 2013 | 06:59 PM
Already MPFI its just obd0 iam doing the b20b vtec swap which doesn't have anything on the back of the motor that my first gen b16a has so iam just trying to get my fan working like stock or any other way I can get it to work btw its also going to be driven on the street from time to time and dragstrip use.
Old Sep 16, 2013 | 07:09 PM
Technical Hero
Wire the block fan switch wires to the thermo housing switch.
Old Sep 16, 2013 | 11:12 PM
Ok ill give it a shot thanks.
kamakaze1
14
May 8, 2009 07:05 AM
da.nizzle
Sep 12, 2008 06:04 PM
BeniRacing
Jun 30, 2007 06:40 PM
WS6Dreams
Nov 21, 2005 06:42 AM
