door locks and trunk wont lock
Old Sep 16, 2013 | 12:25 AM
re rex's Avatar
Default door locks and trunk wont lock
Key fits and works, but the doors won't lock and only way to into the trunk is the lever in the front. Is there a fix for this?
Btw its power locks.
Old Sep 16, 2013 | 06:02 AM
fcm's Avatar
fcm
Old Fart
Default Re: door locks and trunk wont lock
Check linkage.
If the key works, [turns] but will not lock/unlock the doors it can only be a linkage problem.
Does manual lock/unlock "****" inside the door work?
MM&Y of car would help.94
Old Sep 16, 2013 | 05:08 PM
re rex's Avatar
Electric locks and it won't set but its a 94 integra
Old Sep 17, 2013 | 06:21 AM
fcm's Avatar
fcm
Old Fart
Does that mean you can lock the doors, [manually] but not with the power door lock switch or "central locking", [using key in drivers door to lock/unlock pass. door]? 94
Old Sep 17, 2013 | 01:01 PM
re rex's Avatar
Its not working either
Old Sep 18, 2013 | 06:23 AM
fcm's Avatar
fcm
Old Fart
Pull door panels and check linkage.
MM&Y of car???94
Old Sep 18, 2013 | 11:01 AM
re rex's Avatar
94 acura integra
Old Sep 18, 2013 | 02:46 PM
fcm's Avatar
fcm
Old Fart
Pull rear trim panel and check hatch latch linkage.
The 94 Integra does not have power lock/release for the hatch, I know because I have a 94 RS and Mitchell on demand does not show it on any model of the 94.
Old Sep 18, 2013 | 03:15 PM
re rex's Avatar
Its deal in the front pops it down by the gas thing
Old Sep 18, 2013 | 03:22 PM
fcm's Avatar
fcm
Old Fart
What??? 94
Old Sep 18, 2013 | 04:07 PM
re rex's Avatar
It was posted earlier its a 94 integra
Old Sep 19, 2013 | 05:52 AM
fcm's Avatar
fcm
Old Fart
No, I meant what does, "Its deal in the front pops it down by the gas thing" mean? 94
Old Sep 19, 2013 | 02:56 PM
re rex's Avatar
The lever in the floor
Old Sep 19, 2013 | 03:23 PM
fcm's Avatar
fcm
Old Fart
OIC, then it can only be a linkage problem for both the doors ant the trunk. 94
Old Nov 19, 2013 | 07:01 PM
re rex's Avatar
Is the linkage easy to get to?
Old Nov 20, 2013 | 03:17 AM
kaycee_00's Avatar
The rear yes, take the back plastic off and look where the lock assembly is, you should see a metal rod either on the plastic or hanging free. Just connect it back to where it goes and the trunk should be working again.
For the doors, take off the door panel and look up towards the handle, in the left corner you'll see the linkage that goes down to the latch. Make sure its connected and free moving.
Old Nov 20, 2013 | 01:51 PM
re rex's Avatar
Ok thanks Ill do this tomorrow and make sure I can get it all fixed cause my electric locks won't even lock
Banner
Apr 15, 2014 01:28 PM
hericose
Nov 11, 2012 08:42 PM
Acurazor
Dec 27, 2008 06:13 PM
shutupnsk8
Audio / Security / Video
Oct 19, 2005 12:01 PM
grimmace
Sep 29, 2004 08:20 PM
