D16 Motor Ticking HELP
I have a turbo d16 and its tuned on a basemap for my setup im running 6-7 psi so nothing much. Recently Ive been hearing tick when I give it gas and the ticking has gradually gotten louder. Could this be my valves? Valve adjustment? Valve Lifters? any suggestions
Thanks
Thanks
Thanks
Drain your oil make to make sure you didn't kill the bearings. D16 turbo can be fun but NEED to be tuned correctly just like any other engine. If you find bearing in the oil then its a good possibility detenation even so slight could've killed it. If you find nothing check you valve lash, do a leak down and once you figure out the issue be sure to get a proper tune.
RTW DC2R
May 20, 2003 08:41 PM
