Turbo D16 Motor Ticking HELP
I have a turbo d16 and its tuned on a basemap for my setup im running 6-7 psi so nothing much. Recently Ive been hearing tick when I give it gas and the ticking has gradually gotten louder. Could this be my valves? Valve adjustment? Valve Lifters? any suggestions
Thanks
Thanks
Re: Turbo D16 Motor Ticking HELP
Its tuned on a basemap ? That isn't tuned thats a basemap to start tuning from. SMH no one on this site will ever learn or just learn the hard way
Try your best to isolate the noise, all the information you have given at this point can relate to a lot of things that might have to do with belt or fan path items (alternator, a/c pump, water pump, etc.) So isolate the noise and symptoms throughout rpm range (noise gradually increases or goes away).
Heres a little video clip , lemme know what u think
http://www.youtube.com/watch?v=6raEp...ature=youtu.be
Who is Mr Robot?
Could be an exhaust leak
Or
Valve lash
injectors ticking (normal for most large aftermarket injectors)
Start of rod knock or a spun bearing (wost case) I had my y8 lose an oil pump but the exhaust was so loud I couldn't hear it while driving, only when I pulled over and opened the hood and revved the motor could I hear just how bad the rod knock was (spun all 4 rod and main bearings, even spun the cam in the head)
Or
Valve lash
I took it to a local shop today and he sourced it out to be a vacume leak on my manifold so im gonna get a new thicker gasket and well see how that goes. Thanks a lot guys
Kid-jdm-teggy
02-27-2014 06:46 AM
99redSIR
07-11-2009 12:52 AM
