New To Me GSR Sedan Project
Was my sons car, he put a hole in the block, he bought a new 2013 CRZ, I inherited a car with a busted motor.
But I will rebuild and replace. She will run again.
The suspension is ****, fart can is too loud, looking for some new stuff...
Was looking at Tokico blue w/ red springs but they in bankruptcy or some type of restructuring ..
Eying Buddy Club Exhaust... Don't want a big *** can,,,
I'm no stranger to turning a wrench.
I want to rebuild my front end, front end is vague and kinda loose.. So I figure I rebuild it..
I have been pricing Moog parts (always had good success with them)
Lower ball joints, tie rod ends...
The rear is another story & I still need a good set of shocks and springs..
It's a daily driver, no racing...
But some spirited driving from time to time..
Going by the picture below, I think I need new tires..
Anyways, while new to me tires were being installed I noticed the car is sitting on coilovers.. I could not see any marking on them, don't know the brand... Now I need to raise it a little..
I know how to raise it, but no idea on rebound and such..
But still rather have a spring/strut combo.. I want it lowered, but a decent ride..
received my stereo today..
Alpine UTE-42bt - Head Unit - NEW
Alpine KTP-445a - Amp - NEW
10in powered bazooka tube - Was in my Jeep...
Already had Boston Acoustic Speakers all the way around..
Just purchased the following off of Amazon...
1ea-Moog ES3331R Steering Center Link Tie Rod End Moog ES3331R Steering Center Link Tie Rod End
1ea- Moog ES3332R Steering Center Link Tie Rod End Moog ES3332R Steering Center Link Tie Rod End
2ea- Moog EV299 Steering Center Link Tie Rod End 2 of Moog EV299 Steering Center Link Tie Rod End
2ea- Moog K9802 Ball Joint
Cluster Issue, I have 3 clusters, that each had a different issue, I combined what I could to make one..
BUTTTTT!!
When I open the door: the ABS light turns on...
When I fasten my seatbelt: the door ajar light goes out...
Temp, rpm, gas & speedo work fine..( which were most important to me)
But I know it will bug me...
Hoping it is an easy fix...
Any thoughts???
BUTTTTT!!
Any thoughts???
What are the clusters?
What years?
The wiring changed when the changed the clusters from 98-01
You may to combine them differently into the right housing
Take a look at this diagram:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/94-97-98-01-integra-cluster-into-92-95-96-00-civic-wiring-diagrams-1053318/
What years?
AAAHHH!!
I just looked at them and noticed the icon's are in different locations..
I will attempt to swap them from one another..
Hopefully those little red icon thingy s wont give me a hard time..
I'll just get more Jager...
THANK YOU VERY MUCH DEVING916....
Suspension Guru's
I have the following
Buddy Club Upper Control Arms
Moog Lower Ball Joints
Moog Outer Tie Rod Ends
Moog Inner Tie Rod Ends
Tein S Tech Springs
KYB AGX Struts
Blackworks Rear LCA's
Ebay Rear Camber Kit
Is anything else needed???
I know my dumb *** is missing something...
Future Purchases
ASR Type rear Brace
Energy Suspension Hyper Flex Master Bushing Kit
Megan Racing Trailing Arm Bushings
Tein S Tech Springs
KYB AGX Struts
Future Purchases
ASR Type rear Brace
