Honda CR-V & Element 2WD & 4WD Element & CR-V
A/C wiring
Old Sep 15, 2013 | 05:01 AM
sonnyny's Avatar
Default A/C wiring
Hi- Anybody have the a/c wiring diagram for an 03' CRV? Here's what's going on.
Turn on a/c and both fans run, low side pressure is 40 psi and has not leaked, clutch does not engage. I jumped the pressure switch but clutch does not engage. Replaced the clutch still will not engage. I also checked the compressor while apart and it spins free. I need the wire color codes in the harness, the a/c schematic, troubleshooting chart, or any techs want to chime in would be appreciated. Thanks!
Old Sep 16, 2013 | 07:27 AM
PhilStubbs's Avatar
Default Re: A/C wiring
Does your blower fan work on all speeds? Try swapping the relays around. The radiator fan relay should be identical to the compressor relay.
Old Sep 17, 2013 | 04:19 AM
sonnyny's Avatar
Thanks for the reply. Yes the blower functions as it should. I forgot to mention that I did swap the relays around. They are all good. I need to know where the clutch gets it's signal/power from ie. pressure switch to clutch. The clutch single wire runs into a connector with multiple wires and then into a harness.
Old Sep 17, 2013 | 06:10 AM
PhilStubbs's Avatar
On yours I'm not sure, but I know the 1st gen crv a/c wiring almost like the back of my hand. The climate control panel sends out a ground to the pressure switch, if pressure is good it then goes to the ecu. The ecu increases iacv duty cycle and sends 2 separate ground signals. One goes to the fan relay and one goes to the a/c clutch relay. I should also note, if an a/c parameter is not met or the a/c is off, there is a 5v+ signal in all of that wiring instead.
Old Sep 18, 2013 | 06:31 AM
sonnyny's Avatar
Default Re: A/C wiring/Circuit 03' CRV
Okay that helps, thanks. I am getting 12+V at the a/c connector plug when the system is on so I must have a bad ground at the compressor. I'll check area where the coil (-)green wire bolts to the compressor and work backwards. Was trying to avoid pulling everything apart again.
I could still use a diagram of the a/c circuit if anybody has one.
Thanks!
Old Sep 20, 2013 | 10:04 AM
sonnyny's Avatar
Here is the problem circled in the pic. It's the round copper part that the clutch(+) wire joins the harness (+) wire. Looks like a rely or resistor. There is no voltage going from the harness wire to the clutch wire. Anybody know if it's okay to bypass it and what it's function is?
Name:  03'crv compressor.jpg
Old Sep 20, 2013 | 10:13 AM
PhilStubbs's Avatar
No pic
Old Sep 20, 2013 | 01:04 PM
sonnyny's Avatar
Default Re: A/C wiring Solved
Got it. It's a thermal protector. Honda sells it as a unit with wire conector soldered in for $60. Going to just bypass it for now and look for one with the same rating for a few bucks at mouser.com. Just thought somebody else could use the info someday.
Old Sep 20, 2013 | 05:48 PM
PhilStubbs's Avatar
Makes sense. I have never seen one befire
Old Sep 22, 2013 | 03:52 AM
jerinbd445's Avatar
May your blowing apparatus lover work towards most data transfer speeds? Try out replacing the particular relays all-around. The particular radiator lover relay ought to be the same for the compressor relay.
rockycat
Aug 26, 2014 05:35 PM
tdenneson
Jun 8, 2012 06:08 AM
ekcoupeh22
Feb 13, 2012 05:18 PM
02crvdude
Jul 18, 2010 09:33 PM
vanser3004
Honda Civic (2001 - 2005)
May 31, 2010 04:46 PM
