'94 Civic - Bolts for air filter assembly
Hello all,
I'm missing two bolts that hold the air filter box in place. The previous owner had some cheap intake in there so I just opted for the factory set-up and he threw it in last minute the day I picked it up. Looking at the Honda diagram it looks like I need two of #19. I'm confused about the other parts, the rubber collar and mounting. What all do I need to order?
Here's the Honda diagram for my model Civic:
And here's the missing bolts on my air box:
Looks like the rubber gasket you can see is part #2 on the diagram. So should I just need to the bolts?
Thanks in advance!
Thanks in advance!
Yes, 4 and 2 are already there. You only need two of 19. You can probably get it cheaper from your local hardware store than ordering it from Honda. It's not a load-bearing bolt, so it doesn't need to be OEM amazing tasty expensive stuff.
Hello all,
Thanks in advance!
Thanks in advance!
Heyyy if ur in SoCal, I have various length of 10mm bolts that u might need. So, lmk...I gotchu, it's FREE!!!
Thanks JNocon but I'm up in BC so it'd be a bit of a drive
I might just try something from Can Tre but I figured since I was getting a few other things from Honda I might as well order bolts at the same time. I've become a bit of an OEM junkie since learning my lesson on the dizzy...
CivicSi707
Honda Civic (2001 - 2005)
Jul 23, 2007 02:04 PM
