RPMS
I just bought my Honda Civic 99 HX!! But I've noticed that the RPMs Move up and down when the car is warm and when I come to a full stop that's where the needle moves up and down kinda like it wants to turn off it does that one or two times then goes back to normal once I drive it but again this happens when I come to a full stop.. I know this isn't normal what can I do to fix this problem?
YOU NEED TO REMOVE THE IDLE AIR CONTROL VALVE AND CLEAN IT. WHEN YOU ARE DONE IT WILL RUN MUCH BETTER. WHILE YOU ARE AT IT GRAB A BOTTLE OF SEAFOAM CARB CLEANER AND CLEAN UP THAT THROTTLE BODY.
GOOD LUCK SON.
GOOD LUCK SON.
Remove the air intake system and, when the idle is surging, use your finger to cover the hole/port leading to the IACV. Does the idle speed settle down? If not, you have an intake air or vacuum leak. If so, start by adjusting the idle speed as per instructions in the service manual.
blueshark123
12
Aug 18, 2008 01:11 PM
ezeedude
16
Feb 26, 2008 12:06 PM
