Charging light on 3 months after alternator replacement.
Old Sep 13, 2013 | 06:49 PM
CptHMCrunch's Avatar
Default Charging light on 3 months after alternator replacement.
Hey guys, a couple days ago I noticed my charging system light faintly coming on while coming to a stop. When I first come to a stop the charging system light will come on faintly. The light will then turn off and stay off. If I press the gas the light will once again faintly glow as the vehicle reaches idle then turn off.
If I put the vehicle in 1st gear and allow the vehicle to drive forward at idle speed, the charging system light will faintly glow. If I put the vehicle in 2nd gear and allow the vehicle to drive forward at idle speed the charging system light will glow strongly.
Two days ago I came out of class and my car was dead. I thought I left the headlights on, but I may have turned them on before I attempted to start the car. I got a jump start from a jeep and the car ran well. The next morning I tried to start my car and got nothing. I tried to jump the car and got nothing. I had no spark. I replaced the ICM (note: I watched the ICM pass the autozone testing) to get spark, pretty sure the jeep fried it.
After replacing ICM and prior to jump starting car I test battery at ~9v.
After jump starting the car I tested between battery terminals for ~15.5v.
After driving the car ~15 minutes I tested between terminals for ~13.2v WITHOUT headlights on. Tested between terminals for ~12.8v with headlights on.
After ~15 minutes driving the highest possible battery voltage I could read was 13.66v while at ~2000 RPM.
Immediately after driving tested battery for ~11.8v
Battery and Alternator were both replaced July 2013. Any ideas? I am going with bad alternator.
Old Sep 13, 2013 | 07:47 PM
RPM_69's Avatar
Try checking your alternator bracket and bolts. Had a similar issue. It was the lower alternator bolt. The upper one was OK and the tension felt right, but when the car was running I would get a battery light at lower RPMs. Eventually found it and tightened it. I suspect there was just enough wiggle to cause problems.
Old Sep 14, 2013 | 04:32 PM
Tyson's Avatar
Default Re: Charging light on 3 months after alternator replacement.
You got a bum rebuild. It happens. A lot.
sumdewd
17
Mar 22, 2019 04:28 AM
DC5mike
Jan 6, 2008 06:32 PM
bobjohnson
Aug 8, 2007 12:15 PM
zcivicz
Dec 5, 2005 10:44 AM
mntdewred
Nov 18, 2003 05:10 PM
