Mugen Intake, SMSP Header, Benson Block, Toda Spec C Cams
Old Sep 13, 2013 | 05:33 PM
MOVE OVER's Avatar
Icon5 SMSP Header, Toda Spec C Cams, ITR tranny with MFactory 4.785, Synchrotech
Asking/Offering Price: See below
Email Address/Phone Number (optional): PM
Please use PM and I will respond as soon as possible.
I will accept paypal if the buyer pays the fee. Otherwise, cash and check are fine but will clear before shipping. All items are located in Topeka, KS.
USDM ITR Steering wheel with airbag. $80 shipped
Used Passenger airbag. $160 shipped
OEM CPK with bracket, sensor, and bolts. $70 Shipped
Brand new Hondata S300 V2 with OBD2A P28 ECU. No jumper harness needed. Clear protective cover on the ECU lid. It is in perfect condition. $680 shipped OBO. Just the S300 will be $490 shipped
SMSP B19 Header. $950 shipped. No dents, Excellent condition. 10/14:
(2 pics taken, 1 with flash and 1 without flash so you can see what it looks like in different lighting)
Toda Spec C Cams. Excellent condition $650 shipped.
Mishimoto Radiator for DC2, may fit others. I had custom brackets made to allow the use of OEM fans/shrouds. Comes with fans. $250 shipped for the radiator. $300 shipped with fans
B Series Starter. NAPA replacement. 300 miles old. Taking reasonable offers.
B Series Alternator. NAPA replacement. 200 miles old. $170 shipped OBO
RC 370 CC Saturated injectors. With original box and Injector Balance / Calibration report. These have less than 1k miles on them. $200 shipped
Mugen Baffled Oil Pan. No Dents. Excellent Condition. $275 shipped OBO
Fuel Rail. 102k miles. Make offer
Fuel Pressure Regulator. 102k miles. Make offer. See pic above
USDM 98 ITR ECU, OBD2A. No Immobilizer on the 98 ECUs. $240 shipped
Used B series Cam Gears. $20 shipped.
USED ITR Rods (3), Pistons (3), and Main Bolts. Make offer!
ITR Spark Plug Cover. $25 Shipped. **SOLD**
Gates Racing Timing Belt. Made with Kevlar. Blue in color. Used for about 700 miles, excellent condition. $50 shipped **SOLD**
Timing belt covers. I have lower cover, rear upper and front upper cover. The upper covers have been cut for cam gear access and so the cams can be removed without removing the rear upper timing cover. Taking offes. **SOLD**
I have one new and one used Hondata heatshield gasket. Make offers. **SOLD**
98 ITR Engine Bay Harness. Taking reasonable offers, not sure on a price yet. **SOLD**
Endyn Oil Catch Can. AN fittings not included. Brass NPT fittings that come with the kit will be included. Filter, mounting clamp (not pictured), rubber top mount and PCV valve and black hose included. $110 Shipped OBO. Slight dent on can where the mounting band tightens down (the can is soft metal) **SOLD**
Skunk2 6 Bolt Adjustable Cam Gears. Excellent Condition. $90 shipped OBO **SOLD**
HardRace Hard Rubber B Series Mounts. Excellent Condition. Does not include brackets. $150 shipped **SOLD**
OEM Plug Wires. These have about 1k miles on them. $40 Shipped **SOLD**
USDM ITR Valve Cover. $125 shipped OBO **SOLD**
King Motorsports Extended Studs. Used. - $25 shipped **SOLD**
JDM ITR Intake Manifold. *The JDM manifold had an extra vacuum port on the back. The nipple was removed and the hole was welded shut. IAT sensor and IACV included. $160 shipped. **SOLD**
Mugen Air Intake for DC2. Excellent condition, will come with OEM ITR intake arm. $500 shipped. **SOLD**
USDM ITR Cams. 98 or 01, can check to be sure if it matters. $300 shipped OBO. **SOLD**
USDM ITR Throttle Body. Complete with Honda TPS and Map. $110 shipped. **SOLD**
OBD2A to OBD1 Conversion Harness. This one was purchased new about 7 years ago and has been on the shelf for the past 3 years. I think it is a Kenji harness. $40 shipped **SOLD**
USDM ITR Head. New Honda LMAs (spring type, not the old style hydraulic), Supertech bronze valve guides, OEM intake valves, Supertech Inconel exhaust valves, Supertech HD springs, seals, keepers, as well as steel retainers. Intake valves were back cut and all were lapped. Less than 1k miles on all these parts. $850 shipped OBO. **SOLD**
Used OEM B series oil squirters. $10 shipped. **SOLD**
B series water pipe. Coolant nipple has been cut off and welded shut. Use this to eliminate the needless coolant line going to the throttle body and help keep your intake temps down. $25 shipped OBO **SOLD**
ITR Oil Pan. No dents. Great condition. $60 shipped **SOLD**
ITR Oil Pump. ~20k miles. $55 shipped **SOLD**
OEM ITR Oil Pickup. ~400 miles on it. $20 shipped **SOLD**
OEM injectors. Set of 4. About 55-60k miles on them. $36 shipped **SOLD**
USDM ITR Tranny Dealer Replacement Tranny with MFactory 4.785 Final Drive, OEM LSD, and 1-5 SynchroTech carbon synchros. ~28k miles on the gearing, 1k miles or less on the final drive and carbon synchros. New 3/4 sleeve set about 3k miles ago. $1,180 shipped. **SOLD**
ARP Head Studs. Torqued 4-5 times. $55 Shipped **SOLD**
Timing Belt Tensioner. Less than 1,000 miles. With bolt and spring $35 **SOLD**
Thermo Housing with NAPA OE replacement thermo (~1k miles), temp sensor (only part of the plastic is broken but still 100% functional!), bolts, and the U hose. $40 shipped. **SOLD**
ITR Valve Over. $90 shipped. **SOLD**
ITR Crank Pulley. Fairly new, maybe 5,000 miles on it. $70 shipped OBO **SOLD**
Brand new main engine seals (2) **SOLD**
Used ITR LMAs **SOLD**
Barely used ITR timing belt **SOLD**
Brand new Exedy throw out bearing **SOLD**
Used OEM synchro set **SOLD**
Used ITR Water pumps. $25 shipped **SOLD**
OEM ITR Oil Cooler. $55 shipped **SOLD**
Old Sep 13, 2013 | 06:12 PM
budman123's Avatar
Default Re: Mugen Intake, SMSP Header, Benson Block, Toda Spec C Cams
r u selling that endyn breather/catch can?
Old Sep 15, 2013 | 04:48 AM
TravisBiggie's Avatar
Interested in block. Flexible on price? Serious buyer with cash in hand.
Old Sep 15, 2013 | 04:52 AM
Tsimpson's Avatar
any pics of the motor mounts?
Old Sep 17, 2013 | 07:56 AM
MOVE OVER's Avatar
Yes, the Endyn can and vented JDM valve cover, laser cut for cam gear tuning is for sale as well. More pics available upon request. PM me an offer on the catch can setup.
Old Sep 17, 2013 | 07:58 AM
MOVE OVER's Avatar
Price on the block (with crank, pistons, etc.) is firm. If you just wanted the block then I would be open to offers.
Old Sep 17, 2013 | 08:00 AM
MOVE OVER's Avatar
I can get pics of the mounts once the motor is pulled. For now, see this link with pics - best I can do with the motor still in.
http://s1167.photobucket.com/user/it...%20Sept%202013
Old Sep 17, 2013 | 09:29 AM
jdmdb8r's Avatar
great price on that itr block. should sell quick.
Old Sep 29, 2013 | 08:05 AM
blkteg21's Avatar
pmd
Old Sep 29, 2013 | 08:23 AM
99SlammedCivic's Avatar
Snipper Snapper
Nice parts - great seller - buy with confidence
Old Sep 29, 2013 | 09:44 PM
MOVE OVER's Avatar
New items added.
Old Oct 2, 2013 | 10:11 AM
blkteg21's Avatar
pmd
Old Oct 2, 2013 | 08:18 PM
blkteg21's Avatar
payment sent for Hardrace mounts.
Old Oct 4, 2013 | 07:56 AM
Tsimpson's Avatar
Do u still have the water pipe and oil cooler. Pm me
Old Oct 5, 2013 | 08:32 PM
MOVE OVER's Avatar
PMs replied. Items shipped and thread updated with new items. Others will be added soon.
Old Oct 6, 2013 | 09:55 AM
boostkid345's Avatar
Interested in the obd2a hondata pm me if it's still for sale
Old Oct 6, 2013 | 10:05 AM
MOVE OVER's Avatar
Still available. PM sent
Old Oct 6, 2013 | 01:22 PM
DBiNfEcTeD*'s Avatar
Lovely stuff. Interested in the spark plug cover. Ready for purchase
Old Oct 7, 2013 | 11:57 AM
blkteg21's Avatar
got the mounts in today. They are as described. Thanks again.
Old Oct 7, 2013 | 02:39 PM
turbo__man's Avatar
Do you have pictures of the type r cams?
Old Oct 7, 2013 | 07:38 PM
MOVE OVER's Avatar
Thanks!
Pics of ITR cams added!
Old Oct 8, 2013 | 05:16 AM
turbo__man's Avatar
Pm sent
Old Oct 10, 2013 | 08:47 PM
MOVE OVER's Avatar
TTT
Need to get this B19 4-2-1 header and ITR tranny sold!
Old Oct 14, 2013 | 08:33 PM
MOVE OVER's Avatar
Bump. Header is getting polished. New pics added
Old Oct 14, 2013 | 10:11 PM
DC4KiD's Avatar
Those are OEM OBD2 ITR injectors right? If so, please PM me your PayPal addy.
Thanks
