97 DX non vtec harness on 98 gsr
Old Sep 13, 2013 | 04:19 PM
KidRuthless's Avatar
Icon6 97 DX non vtec harness on 98 gsr
Okay I'm having trouble with the wiring from the motor to the ECU plugs. Here is is what I have so far and if I'm missing something please let me know.
So using the non-vtec harness I wire the 2 wire IACV to pin 14 which is relocated to the empty 12 slot then completely remove pin 13. Is there anything else that should be wired for the IACV because there should be a positive and negative but pin 14 would only be one of those?
Now for the vtec solenoid and vtec pressure switch I wired it directly into the jumper harness plugs which connect to the ECU and since I'm running a chipped p-28 there would be know need to wire the knock sensor correct? Am I missing anything else?
Also tried uploading an image from my phone, but Hondatech is asking for a link.
JDMjackyboy
May 31, 2011 07:03 PM
TeamRPM_ZC
Jul 14, 2008 08:36 AM
Bulli Kid
Jun 11, 2007 03:17 PM
GreddyCivic7
Feb 10, 2007 03:35 PM
hatchedzex
Apr 12, 2004 02:41 PM
