Glue under emblems...
Old Oct 26, 2002 | 12:49 AM
964drVic's Avatar
Default Glue under emblems...
My LX badge was fallin' off so I jus took it the rest of the way off... anyone know of anything I can use to get the ugly glue off underneath w/o harming the finish?
Thanks in advance for any insight...
Old Oct 26, 2002 | 12:56 AM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: Glue under emblems... (964drVic)
It should be adhesive and not glue, trying using some Goo Gone, which can be easily purchased at some hardware stores, it should take off the adhesive with a little elbow grease. Use 3M tape to get the emblem back on if you like.
Old Oct 26, 2002 | 01:09 AM
BlackDeuceCoupe's Avatar
HT White Ops
I use a product called DeSolve-It. It's totally safe. You can buy it at any grocery store, Wal-Mart, et cetera. It's good for all kinds of clean-ups. Good stuff to have around....
Old Oct 26, 2002 | 10:09 AM
M-EJ1's Avatar
I used goo gone when I took my Civic EX sticker off my trunklid. Just get a soft rag and put a little on there and rub on the adhesive, that stuff will just come right off. After you're done, wash that section to get rid of any oils from the goo gone and apply a little bit of wax where the sticker used to be.
Old Oct 26, 2002 | 01:15 PM
AWD: Jeff's Avatar
Default Re: Glue under emblems... (matt-eg)
you can use rubbing compound. im not sure where you get it at. i just found it in my garage and took off the gunk.
Old Oct 26, 2002 | 03:46 PM
.BULLET.'s Avatar
From: kapalua,los angeles,las vegas, HI,CA,NV, United States
Default Re: Glue under emblems... (sohc93hatch)
i used MEGUIRES scratch off...it removes almost anything from dirt, bird crap, adhesives, etc...i used it to remove the CIVIC and the EX badge...looks very clean
Old Oct 26, 2002 | 06:09 PM
HT White Ops
Default Re: Glue under emblems... (SHAUNTS99)
It should be adhesive and not glue... take off the adhesive with a little elbow grease....
It should be personal lubricant and not grease...
likeahstone
Paint and Body
Aug 26, 2008 12:18 AM
will7
Jan 10, 2006 07:54 PM
jdmitr01
Feb 21, 2004 10:39 AM
Audio28
Jan 8, 2003 07:41 PM
