failed smog. high nox.
Old Sep 12, 2013 | 09:50 AM
mish__'s Avatar
Default failed smog. high nox.
97 honda del sol si. D16y8. Failed as gross polluter. High nox and no communication to obd2. Should I bother getting it fixed or junk it? My only car and daily.
Old Sep 19, 2013 | 08:04 AM
Global Tech's Avatar
Default Re: failed smog. high nox.
You might ask the inspector if the high nitrogen oxides are due to the converter failure or sensor failure.
Old Sep 19, 2013 | 11:03 AM
shiroitenshi's Avatar
might be your ECU since it fails OBD test.
Old Sep 19, 2013 | 11:46 PM
MAD_MIKE's Avatar
MM Gruppe B
NO MIL/CEL is an automatic fail. Find out why the CEL is not coming on. If the bulb is burned out this may or may not relate to why the scanner is not communicating via the OBDII port. If you have your own scanner does it work/ can you pull codes?
VashTheStampede
Apr 8, 2019 07:28 PM
Lunden83
May 6, 2017 02:13 PM
Littleguy00
Feb 8, 2016 10:16 AM
mish__
15
Sep 7, 2013 06:29 PM
teler86
Oct 8, 2006 06:25 PM
