1998 Civic Power Steering Rack Removal
Old Sep 11, 2013 | 12:12 PM
yohimbine's Avatar
Default 1998 Civic Power Steering Rack Removal
OK, I've memorized the HSM on rack removal and watched all the youtube vids, but after disconnecting everything from my PS rack I still can't get the steering splines to clear the firewall. I spent about 2 hours under the car twisting and turning the thing every way possible with no luck. Yes, the exhaust is disconnected. What am I missing? Anyone have the secret handshake?
Old Sep 11, 2013 | 09:02 PM
knoxrocks222's Avatar
Default Re: 1998 Civic Power Steering Rack Removal
You un did the steering column under the dash right? Make sure your wheels are straight and make sure your steering wheel is straight when you unhook it
Old Sep 12, 2013 | 03:18 AM
yohimbine's Avatar
Yep, the rack is floating free, not attached to anything. The short steering shaft with the spines on it won't clear the hole in the fire wall by about half an inch.
Old Sep 12, 2013 | 01:31 PM
yohimbine's Avatar
OK, I finally figured it out. The trick is to push the driver's side inner tie rod end all the way into the rack. Once I did that the rack came out like S**t out of a goose.
Old Sep 12, 2013 | 08:49 PM
Glad you got it figured out bud, now would be a good time to check or change ball joints as well
Happy wrenching
Knox C.
dr_latino999
Jun 17, 2008 09:59 AM
RanCRX
10
Oct 9, 2007 05:44 PM
DA9_DAD
Oct 3, 2005 06:55 PM
CivicHB93JDM
Sep 8, 2005 09:00 AM
sloweh3
11
Mar 2, 2004 04:38 AM
