B18C4 bad ignition timing problem
Old Sep 10, 2013 | 12:05 PM
xtp's Avatar
xtp
Default B18C4 bad ignition timing problem
Hello, i have swapped B18C4 to EK3. Two years it worked well and in winter I put it out and make some repairs like piston rings, valve seals and etc.
Gave it back and engine works that :
https://www.facebook.com/photo.php?v...type=2&theater
I tried to change : distributor, map sensor, spark plugs, injectors with ramp, ECU, spark cables, checked timing belt, checked wiring and connectors. Timing on distributor is set exactly how before when it worked.
Pressure in engine is: (cold engine)
12.5 - 13 - 13 - 12.5 (in bar)
181 - 188 - 188 - 181 (in psi)
Sparks are wet from gas. No check engine codes.
Can someone help me what is it?
Thanks
Old Sep 11, 2013 | 05:02 AM
GreatWave's Avatar
10 Year Member
Default Re: B18C4 bad ignition timing problem
check your mechanical timing
Old Sep 11, 2013 | 10:19 AM
xtp's Avatar
xtp
checked at first thing, but it is good :-\
joeekrub
17
Dec 8, 2022 08:24 PM
eg grom
19
Jun 22, 2009 06:25 PM
93civicExSI
11
Jul 8, 2006 04:03 PM
pv2dickman
Jun 20, 2006 05:34 AM
