d15b jdm (rocker arm assembly) HELP
Old Sep 9, 2013 | 05:29 PM
playa24vtec's Avatar
Default d15b jdm (rocker arm assembly) HELP
my name is David. I just bought a 95 honda civic about a year ago and just recently I broke my timing belt and bent some valves. I took it all apart and sent my d15b jdm vtec in to get resurfaced and new valves and seals. I took off my rocker arms assembly and cam shaft and pulley. I set them aside in my garage. I just got my head back from the shop and some how I can't find my rocker arms assembly. I put them in my garage with my cam shaft, pulley and dizzy but my rocker arms are missing. Someone took them or I don't know what happen. My question is what rocker arm assembly do I need? And D series? Anyone have them for sale? I need to get my civic back on the road so I really need help with this one people. Also my buddy has an extra d15b non vtec..could i use those rocker arms? All D series should fit on D. Thanks in advance.
Old Sep 9, 2013 | 06:08 PM
94EG8's Avatar
Seagull Management
Default Re: d15b jdm (rocker arm assembly) HELP
If it's an OBD1 D15B Vtec D16Z6 rocker arms are the same.
Old Sep 9, 2013 | 08:18 PM
Do you know anyone from the top of your head whos selling any? thanks
Old Sep 10, 2013 | 12:34 AM
fragmare's Avatar
http://www.hondaautomotiveparts.com
If you need the entire assembly, it's not going to be cheap. You could always head to the junkyard and snag them there too.
Old Sep 10, 2013 | 12:41 AM
mreddy's Avatar
are you thinkin' used oem? where u from?
Old Sep 10, 2013 | 01:14 AM
HondaPartsHero's Avatar
Technical Hero
Junkyard
Old Sep 10, 2013 | 05:27 AM
24TEN's Avatar
PHANTOM MENACE
Is it just the rocker arms themselves that are missing or did you leave the cam caps with them (fully assembled I'm guessing)?
Old Sep 10, 2013 | 05:41 AM
I'm from san diego. Yeah I'm looking for used. My whole rocker arm assembly is gone. I have the cam shaft but no rocker arm assembly. How do I know which rocker arm assebly I can use? Any D series will work?
Old Sep 10, 2013 | 11:01 AM
24TEN's Avatar
PHANTOM MENACE
I don't know if there are any differences between the Z6 and Y8 rocker assembly but you may have a bigger problem. The reason why I was asking if the cam caps are gone too is because they are machined with the head when originally manufactured (matched set). It's not something you can take off of another head and expect to fit without issue. If you replace them with another set you need to look into having the assembly inspected to see if an "align bore" is needed.
Old Sep 10, 2013 | 11:14 AM
I have the cam caps thank god but just missing my rocker arms. I just want to make sure which model will fit so i can go buy some at the junk yard or if someone is selling some.
Old Sep 12, 2013 | 10:40 PM
I need to know which other rocker arm assembly is compatible with the D15B jdm vtec? D16y8? Let me know which model I can use!
Old Sep 13, 2013 | 06:08 AM
p3p69's Avatar
i have a d16z6 head the head itself is bad but all the valves and springs and everything are good (under 8k miles) it has everything you need shoot me an offer of what you need
Old Sep 13, 2013 | 06:12 AM
p3p69's Avatar
i should say the tip of the plug broke off and punched a hole in the head itself everything still functions properly just the head itself is unusable
Old Sep 13, 2013 | 09:48 PM
Will the d16z6 fit my d15b jdm vtec? I just need the rocker arm assembly. Send me a pix!
Old Sep 14, 2013 | 03:33 AM
fragmare's Avatar
Old Sep 14, 2013 | 08:47 AM
really? i asked someone else the other day and someone told me they weren't the same. im getting different answers. i just want to make sure. can you send me a pix of the rocker arms assembly? thanks
Old Sep 14, 2013 | 08:56 AM
94EG8's Avatar
Seagull Management
If it's an OBD1 D15B Vtec then they're same. They share identical head castings (P08) If it's an OBD2 D15B Vtec I'm not sure.
Old Sep 14, 2013 | 09:09 AM
Ok cool. yea its a OBD1. Just wanted to make sure. Thanks.
P3P69 send me a pix? Nothing wrong with the rocker arms? Nothing bent?
Old Sep 15, 2013 | 05:31 PM
JNocon's Avatar
Maybe your rocker arms assembly is just somewhere in the garage, prolly your dad, mom, cousin or brother put it aside in a box. Did u asked them yet? Well, anyway, I have an extra spare of P08 head in great condition I'm selling...here's some pics,
Old Sep 15, 2013 | 09:11 PM
LOL...nah no one put them away. I believe someone who saw me take them off took them. my garage is always open. Anyways..how much u asking? i really only need the rocker arm assembly though.
Old Sep 16, 2013 | 09:33 AM
My head say p08-4. Will this one still work?
Old Sep 16, 2013 | 12:03 PM
94EG8's Avatar
Seagull Management
Yes, as long as it says P08 on it'll work. Keep the sale stuff to PMs please.
Old Sep 16, 2013 | 12:36 PM
Yeah I am keeping to pms unless it says user isn't accepting pms at the moment.
Old Oct 29, 2013 | 07:04 PM
Ok got everything back on. I had my car clicking when trying to start but never turned over. I checked all my wiring and looks like its all connected right. I tried again this morning and now when I push the clutch in and now car won't click at all. My kill switch is disabled but not clicking at all now when I try to start. It worked yesterday but this morning nothing. Almost like the clutch wiring broke or something. Need help. Also I have no power coming out of my ignition coil in my distributor but that's a different story. Please help. Thank you
Old Oct 29, 2013 | 08:51 PM
24TEN's Avatar
PHANTOM MENACE
Clicking? As in the clicking that occurs when you try to crank an engine using a nearly dead battery?
