Poormans R catch can setup HELP
Old Sep 9, 2013 | 11:25 AM
silverteggy94's Avatar
Icon2 Poormans R catch can setup HELP
I have a b18c1 block with a b16 head, itr mani, and ctr cams. Im trying to figure out how to setup a catch can so I can hopefully stop some of the smoking, it doesn't smoke bad just when I hit vtec. I have a spare valve cover with two big welded fittings on the top that I plan on using. I just need to know where to run the lines. thanks !
Old Sep 9, 2013 | 01:28 PM
B_Swapped93's Avatar
Default Re: Poormans R catch can setup HELP
lol a catch can isn't going to STOP you burning oil do a wet compression test i'll bet your rings or possibly seals are shot/going. Catch can=turbo set up no on a "frank" set up.
Old Sep 9, 2013 | 04:28 PM
AndrewS85's Avatar
I guess technically it could help a little. less crank case pressure could equal less oil being pushed past seals, but like B swapped said, you've got other issues
Old Sep 10, 2013 | 11:08 AM
Marvin1985's Avatar
Better change those valve seals.
datoad
Oct 5, 2017 08:31 AM
gaby-dr
Aug 26, 2012 09:21 AM
preludeNApower
Mar 18, 2012 07:21 AM
G-Sum1
Feb 25, 2009 08:11 AM
LSVTEC 91 Civic
Mar 28, 2005 08:27 AM
