SFC VTEC CONTROLER
Old Sep 9, 2013 | 09:22 AM
pop ur vtec's Avatar
Default SFC VTEC CONTROLER
LOOKING FOR SOME DIAGRAMS FOR INSTALLING SFC VTEC CONTROLER ON 99 INTEGRA WITH 96 TYPE R SWAP?http://images.ibsrv.net/ibsrv/res/sr...ilies/thud.gif
Old Sep 9, 2013 | 10:03 AM
Dark_Teg's Avatar
Default Re: SFC VTEC CONTROLER
I have the same motor and have tried several VTEC crossover points over the years. Honda got it right the first time. All changes I made were detrimental.
Old Sep 9, 2013 | 02:12 PM
Spunkster's Avatar
There is much more to VTEC than simply turnign on the solenoid. There are fuel tables in both the low and high cam that must be adjusted.
When tuning with a good system such as Hondata you will see that there are many parameters to change. Different setups require diffeerent VTEC points and the transiion point bay be different from setup to setup. There is also TPS and map pressure to take into cosideration. Hondata also impliments a VTEC window so that at WOT you can get earlier VTEC activation that at part throttle with may need a higher activation or no high cam at all.
Old Sep 9, 2013 | 07:40 PM
doood's Avatar
been there done that
clear enough for you?
Old Sep 10, 2013 | 01:12 PM
B_Swapped93's Avatar
I set my vtec engagement at 800rpm's dat way it sounds like I got dem TODA killer camz at idle y0....bout that lyf
Old Sep 11, 2013 | 03:17 AM
NVturbo's Avatar
O.G. triple O.G.
People still use that CRAP? WOW....
1997 called and they want their "VTAK" controller back.
msbhvn_DC2
Feb 9, 2006 07:39 AM
oalex
Dec 10, 2005 06:51 AM
PM-Performance
Mar 1, 2005 08:45 AM
AllMotor92EG
48
Aug 6, 2004 09:41 PM
xvracing
May 1, 2004 01:49 PM
